turn signals on an 82kz1000ltd
  • Buda
  • Buda's Avatar Topic Author
12 Mar 2009 17:00 - 12 Mar 2009 17:02
#271424
Anybody have a pic of the front turn signals on an 821000LTD. When I bought my bike the front signals were gone.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 12 Mar 2009 17:02 by Buda.
  • kpier998
  • kpier998's Avatar
Re: turn signals on an 82kz1000ltd
12 Mar 2009 17:47
#271431
I just snapped a few and the cell phone I was using went dead. As soon as I charge it up a little and figure out how to post a picture I will do so.
Kirk P
  • Buda
12 Mar 2009 19:18
#271467
Cool
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • kpier998
  • kpier998's Avatar
12 Mar 2009 20:23 - 12 Mar 2009 20:26
#271486
These are from an 82 LTD 1000. They just mount on the oem handlebar. If you have a flat aftermarket, I don't know how well they will work.
Last edit: 12 Mar 2009 20:26 by kpier998. Reason: add picture
  • kpier998
  • kpier998's Avatar
12 Mar 2009 20:26
#271489
Another:
  • kpier998
  • kpier998's Avatar
12 Mar 2009 20:28
#271491
Another angle:
  • kpier998
  • kpier998's Avatar
12 Mar 2009 20:28 - 12 Mar 2009 20:31
#271492
Another angle:
Last edit: 12 Mar 2009 20:31 by kpier998. Reason: Wrong picture
  • kpier998
  • kpier998's Avatar
12 Mar 2009 20:33
#271495
Try that last one again...
  • MFolks
  • MFolks's Avatar
12 Mar 2009 20:54
#271505
If your bike had running lights on the front turn signals you will have three wires going to each of the signals.The wires will usually be inside the headlight housing/shell and have plug in connections or what they call bullet connectors.
The LEFT front turn signal has wires that are comming off the light assembly as: 1.GREY plugged into a GREEN bullet connector wire. This is the turn signal flasher circuit.
2.BLUE wire plugged into the BLUE bullet connector wire. This is the running light circuit.
3. BLACK wire with YELLOW STRIPE plugged into the BLACK wire with YELLOW STRIPE bullet connector. This is the ground circuit.
The RIGHT front turn signal has wires comming off the light assembly as: 1.GREY plugged into a GREY bullet connector wire. This is the turn signal flasher circuit
2. BLUE wire plugged into a BLUE wire bullet connector.
3. BLACK wire with YELLOW STRIPE plugged into the BLACK wire with YELLOW STRIPE bullet connector. This again is the ground circuit.
Taken off my 82 GPZ1100 B2 wiring diagram,Hope this helps............
  • Buda
13 Mar 2009 21:07
#271757
Thanks fellas I dont have them handle bars any more and the turn signels wouldnt fit like that so I will have to find something diffrent.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • kpier998
  • kpier998's Avatar
14 Mar 2009 16:19
#271913
Post up what you decide to do please. I am going to have the same problem as soon as I ditch the handlebars.
