low coil volts
- kfe
low coil volts
11 Mar 2009 20:59
hay guys thanks for your input lastime out i know its going to help. have a ouestion about difrent volts at batt and coil supply its lower at coil.how do i fix this on 78 kz650 any info is appreciated
- PLUMMEN
Re: low coil volts
11 Mar 2009 21:10
id say check your electrical connections would be the first place to start.
- MFolks
Re: low coil volts
11 Mar 2009 21:23
If any of the electrical connections(battery cables,connectors,and ground or earth cables) are dirty,loose or have the green crud of corrosion on them, you will have a voltage drop.
some plastic compatible electrical contact cleaner, pipe cleaners from a smoke shop,400-600 grit sandpaper and time to kill should have an improvement in the coil input voltage
ge.
Check the engine stop switch on the right handlebar pod. They get corrosion in there too.
ge.
- bill_wilcox100
Re: low coil volts
11 Mar 2009 21:39 - 11 Mar 2009 21:41
All the above...
And if you still have the symptom and or want the fattest spark then consider the WG Coil Repowering mod. See:
WG Coil Mod
This is how I implemented the Mod. on my KZ650-B1: See:
My Coil Mod
Best of success.
PS
Please add your year, model and location in your signature to get the best responses... and it's considered real friendly too.
Bill
WG Coil Mod
My Coil Mod
Best of success.
PS
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 11 Mar 2009 21:41 by bill_wilcox100.
- jzanutto
Re: low coil volts
12 Mar 2009 01:56
why are you checking this? is it not running correctly or are you just doing some checking??
There is 1 hot yellow/red wire that feeds both coils- completely disconnect that wire and check with your meter to see if you have battery voltage. You probably will see full battery voltage, and you have no problem.
Reconnect to the coils, and you will notice one coil has lower voltage than the other. This is normal, one coil will have its contact points open (no load) the other coil has its contact points closed (loaded). You are seeing a voltage drop because of the loaded coil.
I had the same indication on my bike. Rotate the crank so the points change position, and you will see the voltage drop move to the other coil.
Now, all this is correct provided you have full battery voltage coming out of that yellow/red wire with both coils disconnected from it. If you have a voltage drop at the supply wire with it disconnected from the coils, then you do have resistance somewhere upstream.
1978 KZ650B 2004 BMW R1150RT
