- Thank you received: 1616
will 2 60w headlight bulbs be too much?
- loudhvx
12 Mar 2009 19:11 - 12 Mar 2009 19:16 #271465
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic will 2 60w headlight bulbs be too much?
A couple years ago I had really good luck finding 35W halogens (H3 and H4) on ebay cheap. Those bulbs are still working too, so apparently they weren't total crap. Don't remember the company, but it was based in China (as soon will be everything ).
Here's some 35w H4's and the price looks good. Never heard of the company, though.
scootrs.com/moreinfo.cfm?Product_ID=1777
1981 KZ550 D1 gpz.
Other links.
Last edit: 12 Mar 2009 19:16 by loudhvx.
- gane
12 Mar 2009 19:44 #271475
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic will 2 60w headlight bulbs be too much?
Random thoughts, Believe H4 is a discription for bulb physical type. IE; 3 blade circular base halogen type. have seen them in many different filament configurations. Yamaha fz's used 35/35. in dual applications, in the day 55/100 were common, and were used by those who needed serious light. a couple things to check. charge rate at batt. (low and high), Heat. I've seen distorted lenses from prolonged use, and draw. the wireing at both h.bar switch and couplers were disigned for much lower draws. consider a relay, handlebar switches are pricy.,luck G
- MFolks
- Thank you received: 540
12 Mar 2009 20:25 #271488
by MFolks
Replied by MFolks on topic will 2 60w headlight bulbs be too much?
The websites
www.rallylights.com
and
www.the12volt.com
both sell heavy duty automotive relays and how to wire them.
Three websites for electrical supplies are:
1. www.easternbeaver.com (funny name, good stuff)
2. www.waytekwire.com
3. www.delcity.net
3. www.delcity.net
