will 2 60w headlight bulbs be too much?
09 Mar 2009 20:05 #270797 by smithgpz
will 2 60w headlight bulbs be too much? was created by smithgpz
the headlight i'm using on my kz1000 has twin bulbs and i was thinking that it might be to much draw for the charging system.i don't ride at night all that often so i'm not worried about how bright it would be.any input would help.does anyone make a lower wattage bulb then a 60watt? if not i might just use 1 bulb.
09 Mar 2009 20:06 #270799 by timebomb33
Replied by timebomb33 on topic will 2 60w headlight bulbs be too much?
what style of bulbs are they.
I THINK MY POWERBAND BROKE
09 Mar 2009 20:12 #270802 by smithgpz
Replied by smithgpz on topic will 2 60w headlight bulbs be too much?
they are h4 and they are 55watt,sorry.
09 Mar 2009 20:18 #270806 by MFolks
Replied by MFolks on topic will 2 60w headlight bulbs be too much?
The old formula for figuring current draw is W/E so 120 Watts divided by 12 volts comes up with 10 Amps.
It might strain your charging system unless you drove at high rpm or went with lower wattage bulbs. It's too much for the switches unless you had a relay control the lights.
09 Mar 2009 20:32 #270810 by timebomb33
look around there is lower wattage h4 bulbs around
09 Mar 2009 20:37 #270811 by smithgpz
thanks.do you know who sells lower watt bulbs?
09 Mar 2009 20:51 #270814 by MFolks
GE, Silvania(SP). Try at www.rallylights.com for relays and wiring diagrams.
09 Mar 2009 20:59 - 09 Mar 2009 21:00 #270818 by timebomb33
by the way what headlight assembly are you using. it looks pretty wild on a z'r.also what type of mounts did you use.
Last edit: 09 Mar 2009 21:00 by timebomb33.
09 Mar 2009 21:15 #270827 by smithgpz
it's a yamaha snowmobile unit and i made my own mounts. it was very simple and took about 1 hour.
09 Mar 2009 21:20 #270829 by bountyhunter
Replied by bountyhunter on topic will 2 60w headlight bulbs be too much?
For a while I ran a second 55W halogen with my main 55W halogen. I wired the second one through a fuse and relay straight to the battery. I am not sure if the alternators are designed to handle an extra 55W or not, but I never blew mine up.
12 Mar 2009 10:55 #271370 by TexasKZ
Replied by TexasKZ on topic will 2 60w headlight bulbs be too much?
Ya might give these guys a shout.
easternbeaver.com/index.html
12 Mar 2009 18:56 #271460 by N0NB
Replied by N0NB on topic will 2 60w headlight bulbs be too much?
Unless you really overloaded the system, it won't blow up. The first symptom will be your battery failing to be charged completely and then failing to hold a charge.
For the OP, you may want to consider wiring up a relay so the second bulb only comes on when you select high beam and then have a separate switch to shut it off if you notice your lights begin to dim (sign that the alternator is not keeping up with the electrical demand). That way you'll be drawing only about five more Watts most of the time (assuming you keep your lights on low beam) which the charging system should handle without issue.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
