small problem
- PDodson
09 Mar 2009 13:21 #270626
by PDodson
small problem was created by PDodson
I would like to eliminate my stock turn signals and install a set of LED blinkers, How would I do that?? I tried but to no avail nothing worked.....since the stock turn signals have 3 wires would I have to splice 2 of the "hot" wires 2gether and use the black and the grnd....?
just another though I didnt try.....
I also have another question on a couple of wires behind he headlight, when I took my headlight out to do the blinkers I noticed they wer not plugged in....when I was done playing I plugged those wire in and the FUEL light came on and stayed on....I unplugged those wires and the FUEL light went off.......any input????
- bountyhunter
- Thank you received: 337
09 Mar 2009 21:24 #270831
by bountyhunter
Replied by bountyhunter on topic small problem
Turn signals have three wires because they are: hot wire to 18W filament, hot wire to 8W filament, ground wire.
