starter location
- jon0108
- rstnick
- Thank you received: 377
The starter on the 650 is on the left behind the cylinders on top of the crankcase.
There should be a rectangular chrome cover with 2 bolts right behind the cylinders.
The starter is under the chrome cover.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- MFolks
- Thank you received: 540
From the positive battery terminal(+) a cable should go to the starter solenoid and then from there to the starter motor. While you've got the motor apart to lube the bushings you might check the carbon brushes for wear and the commutator where they touch for grooving.
Rebuilding kits are available but you need to determine what model and type of starter is on your bike.
- jon0108
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- jon0108
- jon0108
- hugo
- '92 Zephyr 750
- Thank you received: 70
When starter clutch goes bad, it sounds like marbles, or a bad bearing, and engine does not turn. However, it may only fail ocasionally. Mine kept failing about 25% of the time when I got the bike. After a year I got fed up and replaced it with a new one. Did the job myself.
- jon0108
- Link14
- Thank you received: 6
I read both threads about the whining. My bike will start, its just when its really cold and you hit the starter button you hear this horrible whining noise
Jon, if I were a betting man, I'd bet alot that what you're hearing is the starter clutch. When my engines cold on my 750, it will howl like castrated cat when it starts. That sound is the rollers of the starter clutch rubbing against the shaft. Unfortunately the 750 startor clutch isn't behind the rotor on the left side, it's inside the engine. If you search under starter clutch you can find some descriptions about the repair.
Link
- jon0108
- hugo
- '92 Zephyr 750
