Wiring Gurus please!
- roy-b-boy-b
01 Mar 2009 14:42
I installed the MarkII engine into the "77" KZ and the wiring from the stator is diffrent. The wires coming out of the Mark II are all yellow and the wires coming out of the KZ are sky blue,yellow,and pink. They have a blue connector.
How can i wire the yellow wires into the blue connector? Thanks Roy
- hoghaterkaw
Re: Wiring Gurus please!
01 Mar 2009 15:10
Go one step farther and get a solid state combo reg/rec unit and wire the three leads from the stator to the three leads on the combo unit that are the same color. Most combo reg/rec's use red or orange as the positive and black or green as ground.
- bountyhunter
01 Mar 2009 15:17
You need to look at both schematics to see what's what.
Don't know about blue, yellow and pink.
I would guess that means those wires are interchangeable elctrically, and I would GUESS they are the AC wires from the generator field winding going to the rectifiers. That's what they are on mine.The wires coming out of the Mark II are all yellow
- roy-b-boy-b
01 Mar 2009 15:39
On the old bike the old wires go into the regulator and on the newer engine they go into the regulator/rectifer.
Thanks all for the answers. Roy
- timebomb33
01 Mar 2009 17:07
the mark11 charging system is 3 phase with a permanet magnet set-up the early kz's had a single phase alternator the two regulators won't be compatible
I THINK MY POWERBAND BROKE
- roy-b-boy-b
01 Mar 2009 17:41
What do i need to do. Transfer all the components from the three phase bike? Roy
- timebomb33
01 Mar 2009 18:33
you should be able to get away with just the regulator
- wiredgeorge
01 Mar 2009 19:40
Roy, I am pretty sure that the blue, pink, yellow scheme is identical to the yellow, yellow, yellow. Get you a cheap Harbor Freight multimeter and check the three legs off the stator to be sure. With the bike running, you should see about 40 VAC on any combo of the legs just like the yellow wired stators.
- MFolks
01 Mar 2009 20:12
Fully charge the battery and like WG said, start the bike with the wiring from the stator to the rec/reg disconnected take the engine to 4k.
On my 82 GPZ1100 B2 I get about 50 volts A.C. so watch out about shocks. Get a helper as holding a multimeter to the output plug and reving the engine will be a bit much. You need to measure all three legs of the three phase output.
- loudhvx
01 Mar 2009 20:42
On the schematics I've seen, some show the 3-phase stator to have yellow, pink, and blue, while others show three yellows. The yellow, pink, and blue was for the older regulators that needed to have the phases in proper sequence for the reg to work properly. If you just use a modern reg/rec, the sequencing won't matter. Just run the three yellows to a modern reg/rec and you should be fine.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- roy-b-boy-b
02 Mar 2009 03:42
Thanks for all the input. I have had several people to pm me and offer advice and that all helps.
I use to have a good job until UPS bpouht the company and fired every one and i would just hire the work done as i didn't have the time to. Now i got to use my brain and that could be dangerous.:laugh: Roy
