79 KZ650 BATTERYLESS AND BAREBONES
- NICEONE
- "speak softly and carry a BIG STICK"
I'm trying to go batteryless on my 79 kz650, i believe i have a permanent magnet style stator generator(alternator) with two yellow wires coming off of it. No brown wire off of the regulator rectifier. Points.
i got a 50v 10000uf capacitor and hook it up to the battery wires, to test but its not working i kick it doesn't do anything, hook the battery back up kick starts right up.
Am i doing something wrong or am i missing a step. generator has a flywheel not feild coil.
Also i want to go bareback style and ditch all the unnecessary wires, but i'll reply in the other thread.
These sounds very garbled just not sure i'm saying what i'm trying to say correctly.
thanks
NicEone
Indelible Species
79 kz650c BRATBOB
06 SCION XB -goblin green-
94 nissan skyline
- loudhvx
- Thank you received: 1616
Also, if you have a Dyna S ignition, it probably won't work.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- NICEONE
NicEone
Indelible Species
79 kz650c BRATBOB
94 nissan skyline
- NICEONE
NicEone
Indelible Species
79 kz650c BRATBOB
94 nissan skyline
- franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- franknsr
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- loudhvx
During a kick, the alternator should charge the cap during the first half of the kick, then the second half should start the bike. With a battery, if the bike does not start immediately on the first kick, the bike may not be in good enough running condition to use a cap.
How do you have the lights disabled? As I said, even a tail light may be too much drain during the initial startup.
Can you push-start the bike? That will tell if it's a wiring issue or just a hard-start issue. If it won't start from a good push in 3rd gear, then it may not be hooked up correctly or the cap may be bad.
1981 KZ550 D1 gpz.
Other links.
- NICEONE
but here's a questioN, is there a particular brand to use as far as the capacitor i have one from JameCo electric here is the link:
www.jameco.com/webapp/wcs/stores/servlet...CatalogDrillDownView
is this where i'm going wrong?
they were the only place that carried anything near the size capacitor i needed that was close to san francisco.
NicEone
Indelible Species
79 kz650c BRATBOB
94 nissan skyline
- loudhvx
You may have brakelight failure relays and sensors that may need to be disconnected. Also make sure the hazards or turnsignals are not somehow activated.
The problem could also be the reg/rec itself. You'd need an ammeter to measure the current drain on the reg/rec while the battery is connected (with the bike turned off).
The cap you bought looks ok. I usually like the ones with screw terminals. That price is pretty good too. I usually go with Sprague if you can afford it, but they cost more. If you get it working on the Jameco cap, you can always upgrade later (only for reliability purposes).
1981 KZ550 D1 gpz.
Other links.
- NICEONE
batteryless was a go! fired up on the third kick consecutively time and time again. But bike was being shorted out by sparking from the points to the cover, which was in another thread.
But it now runs off of the caps, so i can order better ones to be housed permanently. but for $9 bucks it sure is working out pretty well.
So now i can rewire the bike and get rid of all the stuff i don't need. thanks for the help.
NicEone
Indelible Species
79 kz650c BRATBOB
94 nissan skyline
- Russ Jackson
Okay end result:
When you get it complete could you take pictures and post the entire method and parts you used?...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
