Ground cable on a 78 kz1000
- galaxian
23 Feb 2009 05:57
On the right side of the motor there is a ground cable. What i need to know is where does it attach to? Anyone have a pic pretty please??
1977 KZ1000A1, 1979 KZ650 C3
- inline79
Re: Ground cable on a 78 kz1000
23 Feb 2009 09:35
These are usually bolted right to the crankcase. I'm not sure about the 78 kz1000, I would love to have one to look for this bolt hole on, but on its baby brother, the kz650, it is on the right side behind the oil filler cap. The wire is run under the engine mount and up to the bolt hole.
- MFolks
23 Feb 2009 11:13
If you suspect the grounding cable is faulty(or known as Earth to the Brits.) a replacement can be made for a few $. Remove the cable and visit the local welding supply store and purchase either 8 or 6 gauge welding cable sufficient for your needs.
The welding cable is very flexible and can bend to fit many difficult situations. On wire sizes the smaller the number the larger the conductor.
Then a visit to a local battery shop who can then crimp/solder the correct size terminal lugs on your new cable. Battery cables can fail internally under the insulation on almost any vehicle, but usually on the positive terminal.
All battery terminals must be clean and tight to transmit the high currents needed for starting,and the starter solenoid terminals must also be clean and tight.
A thin coating of vaseline will reduce the chance of corrosion on the battery terminals giving many years of service from the battery.
- galaxian
23 Feb 2009 13:04
Guys thanks for your replies but its a bit of topic. I need to know where the ground connects to (one end to the block and the other end to where???)
23 Feb 2009 13:58
galaxian wrote:
one end to the block and the other end to the negative battery terminal.
Good Luck!
Good Luck!
- galaxian
24 Feb 2009 05:49
Thanks that is what i wanted to hear.
