79 KZ1300 Solenoid Relay clicking
  • BLSSeattle
  • BLSSeattle's Avatar Topic Author
22 Feb 2009 17:38
#267269
Hi all. My 79 KZ1300 was running great and then the other day I tried to start it and after a strange electrical sound (after hitting the start button) the solenoid relay (the component that the positive battery wire leads to) just clicks and nothing else happens. I try to start it and all I get is that relay click. A nice loud ckick. Any ideas as to where to go from here? Is is shot? Thanks for the help. -Michael
  • hoghaterkaw
  • hoghaterkaw's Avatar
Re: 79 KZ1300 Solenoid Relay clicking
22 Feb 2009 17:42
#267274
have you checked the battery voltage?
  • BLSSeattle
22 Feb 2009 17:47
#267276
The voltage is fine. See why is I'm so confused? Electrical problems rule! Not.
  • otakar
  • otakar's Avatar
22 Feb 2009 17:50
#267278
Check the voltage out of the relay while you press the start button. If you have voltage out than it is the starter, if not than it is the relay.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • BLSSeattle
22 Feb 2009 17:58
#267281
Thanks. Out via the two smaller wires or the 2nd large wire?
  • otakar
  • otakar's Avatar
22 Feb 2009 18:05
#267288
Disconnect the starter wire and test that lug and the frame. It may also be that one of those connections are bad or loose. If you get juice out of the starter lug, than check the brushes in your starter or the lug on the starter.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • BLSSeattle
22 Feb 2009 18:15
#267295
Stupid question but what's a lug?
  • otakar
  • otakar's Avatar
22 Feb 2009 18:17
#267299
The terminal that the wire connects to with a nut.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • BLSSeattle
22 Feb 2009 18:20
#267304
Ahh, that makes sense. I huess that's why they call the nuts that hold a tire on "lug" nuts. I'll try all you mentioned. I found a second relay for very cheap so either I have the fix or a cheap spare part. If it's the starter I'll just have to dig a bit deeper into the ol' pocket. Thanks again.
  • otakar
  • otakar's Avatar
22 Feb 2009 18:26
#267309
If it is the starter, most likely it is the brushes and they make rebuild kits for them.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • BLSSeattle
22 Feb 2009 18:32
#267313
But if it's the starter brushes I'd still be hearing something from the starter, wouldn't I? The starter makes not a sound and when I touch it there's no feel of it doing anything. I'd think if it were getting any juice it'd be doing something. Anything.
  • otakar
  • otakar's Avatar
22 Feb 2009 18:35
#267315
Not true. If the brushes (or brush) is gone you will not hear a thing.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
