LED's on the KZ
- otakar
Re: LED's on the KZ
22 Feb 2009 14:01 - 22 Feb 2009 14:02
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 22 Feb 2009 14:02 by otakar.
- Darkangel
Re: LED's on the KZ
22 Feb 2009 19:57
OK more info I like those LED brake lights....Tell me more....
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- otakar
Re: LED's on the KZ
23 Feb 2009 09:52
Well- You can do it a couple of ways. Retro-fit or custom. Mine is Custom. Retro-fit just means that you stick in a couple of LED replacement bulbs and call it quits. This will have one major drawback, Due to the fact that LEDs do not reflect to the rear, the reflectors in the unit are going to be useless. You will most likely wind up with two bright spots and that will be all. The custom route is a different story, as you can tell by the picture it works quite well. I modified a couple of automotive tail lites to do the job. Yes I said couple. since I bought a pair I modified both. These will fit into the later housings such as found on the GPZ or CSR or LTD. It cost me about $150 each to do. You also have to modify the housing holding the sockets by removing them and plugging up the holes installing a new wire harness and wire them in. You can learn more in my thread,
kzrider.com/index.php?option=com_kunena&...&catid=11&id=169462I
do have an extra one.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
Re: LED's on the KZ
04 Mar 2009 04:14 - 04 Mar 2009 04:25
This is easier than you think....
I have a Radii integrated tail light/turn signal unit and you don't need load resistors and all that in most products.... As mentioned by the others, yes, LED draws minimal current (load) where the OEM KZ turn signal relays will recognize this as a burned out bulb...
Simple resolution, Autozone Tridon EP-35 turn signal/flasher relay, ~ $10.
works just fine....
OMR
Here's how I wired mine in....
works just fine....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 04 Mar 2009 04:25 by Old Man Rock.
- Old Man Rock
Re: LED's on the KZ
04 Mar 2009 04:27 - 05 Mar 2009 03:57
arrrgggghhhh... wouldn't edit correctly so trying this again....
Wiring the EP-35 into my 1976 KZ900-A4
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Mar 2009 03:57 by Old Man Rock.
- Old Man Rock
Re: LED's on the KZ
05 Mar 2009 03:58
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Kawickrice
Re: LED's on the KZ
05 Mar 2009 05:56
I installed a 1157 cluster bulb and got a clear lens for my Z1 from Jeff Z1E. I have not messed with my turn signals yet, so I am listening to everyone on this one.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bountyhunter
Re: LED's on the KZ
05 Mar 2009 14:58
Darkangel wrote:
Be careful. I have tried some of the "cluster" bulbs and they were not bright enough for a brake light in daylight, I ended up chucking them.
The best and brightest bulbs which I ended up going to are the 3W Luxeons. They are actually a little brighter than stock lights and are very visible.
www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR
BA15 3-Watt LED bulb
Super Bright 3-Watt High Power LED 12VDC replacement bulb
15mm 1156 Single or 1157 Dual Intensity Bayonet Base
Super Wide 130 Degree Viewing Angle
Select Base type & LED Color
I would like to put LED turn signals on my KZ, but what should I worry about when changing over to LED. because I plan on using cluster lights also for the brake lights.
- baldy110
Re: LED's on the KZ
05 Mar 2009 18:39
This is actually very simple. I replaced my brake/tail light bulb with an drop in replacement LED bulb and changed all my turn signals to LED. All I had to do was replace the turn signal relay with an electronic one which I found at Kragen's for $10.00. Everything works great.
- hugo
- '92 Zephyr 750
Re: LED's on the KZ
06 Mar 2009 12:14
baldy110 wrote:
What LEDs did you get for your turn signals?
