Troubleshooting Snerff 78 KZ1000
  • loudhvx
  • loudhvx's Avatar Topic Author
18 Feb 2009 04:29
#265852
snerff wrote:
I do have another question. When I put the meter across the battery posts with the engine running It was reading almost 17 volts. That seems too much. Could the regulator be bad? Thanks again.
  • loudhvx
Re: Troubleshooting Snerff 78 KZ1000
18 Feb 2009 04:38 - 18 Feb 2009 04:40
#265853
In order to determine if it's the regulator or not, you need to measure some voltages. Keep the black meter lead on the battery's negative post. Measure the voltage on the brown wire at the regulator. It should be around 14v when the motor is revved for a few seconds (and if the battery is somewhat charged). Next measure the voltage on the black wire at the regulator. It should be zero volts.
What voltages do you get?
If the brown wire is at 17v, and the black wire is zero, then the regulator is bad.
If the black wire is anything above 1v, then the ground connection is bad somewhere, or the ground wires are not heavy enough.
If the brown wire is about 14v, and black wire is zero, then the regulator is probably good, and you are losing voltage in the ignition switch, fuse box, or wiring. The path in question is from the battery-positive to solenoid to fuse to ignition switch to brown wire on the reg. Each of those points should be at the same voltage as the battery (while running with the battery at 17v).
Last edit: 18 Feb 2009 04:40 by loudhvx.
  • snerff
  • snerff's Avatar
18 Feb 2009 08:57
#265887
Thanks again, I will try that tomorrow morning. Also Z1 sell a combo unit to replace existing setup. If things are bad mabey I could get that unit. It is supposedly easy to wire up.
  • loudhvx
18 Feb 2009 09:45
#265894
Yes, I would definitely consider that new unit from Z1. The old reg and rec are near the end even if they work now. But still would be nice to know for sure what the existing problem is.
  • snerff
  • snerff's Avatar
19 Feb 2009 07:01
#266133
I checked the regulator this morning. At least 17 on the brown wire and less than 1 volt on the black. Also after the engine was running for a minute the regulator started smoking, so that's the end of the regulator. I ordered the combo unit from Z1. Hopefully you would show me how it will tie in to the diagram you gave me. The Z1 unit is a combo unit:R110-515. I will not know the wiring till it gets here. Thanks again so much.
  • loudhvx
19 Feb 2009 10:12
#266164
Smoking would definitely indicate a bad regulator. :)
Probably for the best. The new unit will simplify the wiring anyway. I can update the drawing when you get it. Just to make sure, you are using the stock charging system, correct? Alternator, that is.
  • MFolks
  • MFolks's Avatar
19 Feb 2009 11:09
#266187
He let out the magic smoke!
  • wiredgeorge
  • wiredgeorge's Avatar
19 Feb 2009 16:23
#266243
loudhvx - You stated:
Help me out here with a bit of clarification. I much appreciate when you make posts as they are informative. IF you have 14 VDC on the brown and zero on the black (ground), how could you have 17 VDC at the battery? Is this what you were saying in the part I quoted or did I misunderstand. Thanks in advance. wg
  • snerff
  • snerff's Avatar
19 Feb 2009 23:53 - 19 Feb 2009 23:54
#266444
It is the alternator with the electronic update.No points.It will probably take about a week to get the Z1 unit. I will let you know than. Thanks again.
Last edit: 19 Feb 2009 23:54 by snerff. Reason: extra
  • loudhvx
20 Feb 2009 09:03 - 20 Feb 2009 09:35
#266484
This is a very common condition when the wiring is old on a stock bike.
Assuming the regulator, rectifier, wiring, and switches are good, this is what normally happens: The alternator puts out as much current as it can. The regulator shorts out as much current to ground as it takes to maintain 14v on it's sense line. The rectifier rectifies the remaining current into DC and that DC gets routed to the battery. The battery voltage gets routed through fuses, ignition switch, and several connectors to finally feed the battery voltage to the regulator's sense line. There is no significant current in the sense line. Notice how it forms a feedback loop. The regulator controls the voltage to the battery based on the voltage it senses on the sense line. If the alternator starts to put out more, the rectifier puts out more and the battery voltage goes up. This raises the voltage on the sense line which in turn causes the regulator to reduce the current to the rectifier (by shunting excess to ground). This will then lower the battery voltage back to 14v. It happens so quickly you may not even notice a fluctuation on a meter.
As I said, the sense line uses very little current, so the wiring of the sense line will cause very little voltage drop. If the sense line were switched directly to the battery without any other devices connected, it would work perfectly. However, the sense line is not exclusively connected to the battery. The sense line is connected to the main circuit coming from the battery. This circuit feeds lights, ignition, and other accessories. This large current draw causes voltage to drop along the path (in the fuse box, switches, etc.) if the wiring is old and switches/connections are dirty. So here's what happens: Let's say the battery for a moment is at 14v. The path, through which the sense line is connected, loses voltage due to the high current load. Lets say the fuse holder drops 1 volt and the switch drops 1 volt. Now the end of the sense line at the regulator is at 12v. The regulator is tricked into sensing battery voltage is 12v. The regulator must therefore increase voltage output by 2 volts to get the battery back to 14. Since the battery is really already at 14v, the extra 2 volts will force the battery to now be at 16v. Notice the regulator is basing it's operation on what voltage it senses from the sense line to ground. Since it is getting an artificially low sense voltage, it forces a much higher battery voltage.
The same thing can happen if the ground connection from battery to regulator is faulty. This is less common (but not uncommon). This will have the same effect, generally speaking.
This whole problem is the same as the low-voltage-to-the-coils problem and is caused by the same type of condition, but in slightly different areas. The coils issue emanates from a slightly later area in the path.
This problem is why it is important to base system voltage readings from the actual negative terminal of the battery and not some other arbitrary ground point, and regulator voltage readings should be done at the battery's positive post. Anywhere else may be misleading. If a problem is detected at the battery, then voltage readings should be done along the path to the regulator to isolate the problem area.
Notice in snerffs case, I told him to verify the voltage on the brown sense wire on the regulator. This was to make sure the sense line was not losing voltage. It wasn't, so therefore, in his case, the regulator was sensing 17v and maintaining 17v. That is a bad regulator.
Notice when the sense line is losing voltage, the regulator is sensing 14v and maintaining 14v. That is a good regulator, but the wiring is forcing a false reading to the regulator. This causes a high voltage reading at the battery. This problem often misleads people into buying new regulators when all they really have to do is clean some contacts and/or restore some wires.
So if a reg/rec combo has it's output wire tied directly to the battery, why use a seperate sense line? That seems redundant. Well, it's because the sense circuitry of the regulator may use a tiny bit of current if it is hooked up to the battery all the time. This may potentially drain the battery. That's why the sense line gets disconnected when the ignition is off. Some reg/rec combos, however, are designed to use so little current they don't need a seperate sense line and "sense" the voltage directly at the output wire (which goes directly to the battery usually via the start solenoid). I believe the 1-phase KZ650 reg/recs do this (circa 1978, 1979). But I think Kaw went back to a sense-line configuration on later models because of possible slow-drains on those 650 reg/recs. There may also be an issue with charging batteries that are still connected to the bike with the no-sense-line reg/recs. Since the sense circuit is connected all the time, a large charging voltage may damage the sense circuit on the reg.
Last edit: 20 Feb 2009 09:35 by loudhvx.
  • inline79
  • inline79's Avatar
20 Feb 2009 12:34
#266556
Definite good info here.
On the KZ650 generator, the history goes something like this:
1977 - field coil style with mechanical regulator and rectifiers
1978 - single-phase stator with reg/rec combo (no sense line)
1981 - three-phase stator with reg/rec combo (w sense line on ignition circuit)
The three-phase system is clearly superior - I am in the middle of upgrading my KZ650C2 to KZ650-H1 stator, reg/rec, ignition systems.
I'm undecided about these sense lines though, and may run mine back to the battery positive. If you have some corrosion in the electrical system, the reg/rec may run at full output and self-destruct. A modern reg/rec should have minimal drain on the output, so if you are parking for a while just disconnect the battery negative.
  • loudhvx
20 Feb 2009 20:06
#266646
I wonder the same thing. Hopefully the new reg/recs without sense lines have no issue with slow draining the battery or damage from battery chargers. It shouldn't be too hard to protect against that.
