Wire job
- dman3998
10 Feb 2009 22:39 #263717
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Wire job was created by dman3998
I am making a new main wire harness from scratch for my 1000B3 and I am using the old one as a pattern.
I have never seen such an unprofessional mess of crap wiring ever!! what a joke, I would not have believed that this came out of a production factory. There are about 10 splices in the middle of the runs where you would NEVER know that they were there, or be able to inspect them to see if they are good. They even change colors in some them too. I am fixing as much of this as I can but no wonder some people have fits tracking down an electrical problem.
I would not recommend making your own harness, its not hard but WAY tedious and time consuming. I bet I will have 40-50 hrs in this by the time I am done. Oh Well.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
11 Feb 2009 00:07 #263731
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Wire job
ya, i know what you meen dman. I made the mistake of making the wiring harness for my 650 from scratch...........arghhhhhhh.........never again, i dropped the f-bomb every other word wile working on that. This winter when it comes to the wiring on my z1 rebuild, i will be ordering a redroduction plug and play harness.......................it is just so much easier.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- MFolks
- Thank you received: 540
11 Feb 2009 06:54 #263773
by MFolks
Replied by MFolks on topic Wire job
A problem with the GPZ's that had FI was the Splices in the FI harness going to the injectors. They would get corrosion in the crimps dropping the voltage to fire the injectors.
I went through mine a few years ago replacing all the crimps with the type used on the F-4 Phantom II.They are a solder sleeve type that contain solder and sealing sleeves that when heated solder the wire and seal it from corrosion.
You have to be carefull doing this as the japanese wire insulation is a fairly low temp type that can burn and melt.
A time consuming chore, but I don't worry about voltage drop anymore.
- Captaingamez
11 Feb 2009 08:00 #263784
by Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
Replied by Captaingamez on topic Wire job
I know all about your trouble man. had to rewire a 1992 cbr one time, man that was a pain. but the rats nest was gone so i guess it was worth it. that job took me and someone else about 12 hours
1971 Yamaha AT1
1971 Skiroule 300rr
