Speedometer
- rtg
Speedometer
24 Feb 2006 09:31
I have an "83 KZ 1100 with a stock, cable -driven speedo that tops out at 85mph...does anyone know WHAT if any speedo with more mph on it could be used as a replacement ??
"83 KZ 1100 A-3 Shaft drive
Post edited by: rtg, at: 2006/02/24 18:26
- wireman
- OKC_Kent
- OKC_Kent
Re: Speedometer
24 Feb 2006 13:40
rtg,
Can you put your bikes model, year, size and your location in your signature? Do you have a Spectre, GPZ, LTD, or other?
If no one else actually knows, I would guess you can buy an early or later model speedo gearbox that attaches to the front wheel. Then get a speedo that goes to 140-160 from that time frame. You have to find out if the different gearbox fits the axle and wheel. I would think it could be a simple swap.
Check the Kawasaki web site for parts diagrams. Start with the axle on your bike and see if any older models used it. If i knew your model I could do it pretty quick tho....:whistle:
Post edited by: OKC_Kent, at: 2006/02/24 16:54
Cashion, OK
78 KZ650 B2 85,000+ miles
- rtg
- wireman
