84 GPZ 550 Reg/Rec
  • dulcimerbob
  • dulcimerbob's Avatar Topic Author
84 GPZ 550 Reg/Rec
25 Jan 2009 07:01
#260044
I need a close up picture of this part where the pigtail goes into the reg to see arrangement of wire colors or for someone to tell me outright. I have no wire harness and am making my own Thanks
  • franknsr
  • franknsr's Avatar
Re: 84 GPZ 550 Reg/Rec
25 Jan 2009 07:35
#260052
Where's the pic?
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
  • MFolks
  • MFolks's Avatar
25 Jan 2009 12:48
#260099
On my 82 GPZ1100 B2 the wiring diagram for the regulator/rectifier has a 6 pin connector with the following wiring colors:
1.Three yellow wires (maybe 16-14 gauge come from the alternator. 2. One white wire with red stripe(maybe 14 gauge) going to the main fuse block for the 30 amp fuse through an eight pin connector.
3.One brown 18-16 gauge wire spliced into other brown wires in the main bundle. 4. One black with yellow stripe 16 gauge wire coming off the negative battery terminal.
  • dulcimerbob
25 Jan 2009 16:38
#260150
Thanks
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
26 Jan 2009 05:04
#260235
I'll see what I can do for you when it get lighter outside Bob. I also have a spare wiring harness I can take some pictures of as well, and e-mail them to you.
So it's the color of the wires going into the multi-pin connector that plugs into the regulator/rectifier, right?
'85 GPz550(ZX550-A2)
