- Thank you received: 4
Acewell Speedometer Questions
- KawiConvert
Also, on a positive note, I put in resistor type plugs and the tach works great. I am using a tach setting of 1 signal = 1RPM. Prior to new resistor plugs the tach was all over the place and rarely consistent.
I would appreciate any help that you can give as I would like to use the bike to commute in the morning. I've been wanting to ride so much that I took it out at 1:00AM just to get a ride in.
KC
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- Oznative
Sounds like you did everything correct. I believe from past posts you are using your old Speedo gear on the front wheel with the conversion cable from Electrosport. If you’re using the reed sensor maybe it’s vibration doing the dirty deed. However if not then maybe it’s a little EMI issue from the high voltage generated by the coils. I can’t get a DVM any closer than 2 feet from my bike when it’s running or the meter goes crazy. Try shielding the cable with foil. Maybe a ferrite bead or two. Try removing the meter but leave it hooked up and see if moving it away from the bike will help. I think its EMI personally.
Good luck
1977 KZ1000 A-1 Just north of Boston
- Old Man Rock
- Thank you received: 225
I use this setting it shows that I am doing 70mph while idling in 2nd gear
Something can't be right here....
Acewell speedometers use Hall Effect sensing for the speed sensing & measurements.
en.wikipedia.org/wiki/Hall_effect_sensor
Basically what happens is this... The sensor is placed in position on the front fork for example and senses a magnet (earth magnet or magnetic rotor bolt) as it rotates around the brake rotor.
So unless you have this senor too close to the magnet/rotor and is picking up motor/frame vibrations, you should measure 0 mph regardless of the rim programmings.
An 18" rim for example equates to 457.2mm...
You may want to check your inch to conversion process or just use basic math for it and see what happens.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- The Fish
- Thank you received: 6
www.electrosport.com/street/speedometers.php
(click on the "more info" Links)
I would assume you would need to know the Speedo ratio (how many times the speedo cable turns per each wheel revolution) and then do some kind of calculation to figure it out (I'm not much help on that :dry: )
I'm surprised that the installations instructions dont have more precise directions/ calculations for setting it up.
- Oznative
- KawiConvert
It is cable drive, no sensor. As for EMI, the plugs are resistor types and I am getting no signs of EMI in the speedos behavior. I did get some with the tach and it would bounce all over (bounce is a relative term), but the speedo is consistent and behaves like everything is fine except for the ridiculous speeds I was hitting.
I think the Fish may be right. Does anyone know what the wheel turns to speedo revolution is in the front drive? That may explain it. I'll try a 3:1 reduction and recheck as that seems close.
- Oznative
- Old Man Rock
Thanks
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KawiConvert
I'll let you know. One thing I am running into is electrical interferance at low RPM's, but I think this may be related to the way the system charges and the fact that I get an odd behavior right off of low idle. According to the Acewell my bike likes 1200 RPM's as an idle. Something else I get to look at.
- KawiConvert
(51/50)*700 = new value
So I am putting 714 back into the bike. My first roll out was 79.875" so a value of 2029. So my final adjusted ratio is 2029/714=2.841 . Not a set ratio, but it works compared to what the Acewell was putting out at first.
Also, at low speeds I had minimal error which led me to believe that it was in the value as an error there would grow with increased speeds compared to some offset that would always be off.
Lastly, use some dielectric grease when you do the connections on these. It has been raining here and that seems to effect the RPM's after a bit of time on the road.
Overall I am happy with the Acewell other than the mount that I had to bend to be able to see the screen. Their mount is for flat mounts, not the angled stock ones on the Kawi. But a little bend in the mount and it works just fine now and is easy to read day and night.
- Oznative
Glad to hear you got your problem ironed out. I took your advice and bought the cable from electrosport and modified it to fit the old speedo gear drive. Now if the weather here will get above 0F one of these days I can put some gas to her and try out the new speedo.
- KawiConvert
