no key???
- TunaTodd
no key???
23 Feb 2006 11:50
While I did recieve the title to my KZ440, I didn't recieve a key. What are the best options for getting all the locks replaced? Would it be easier to have a locksmith make a key for the current locks? Never dealt with keymaking sans an original.....
- ltdrider
Re: no key???
23 Feb 2006 11:59
You can get a key made, if you know the key number. It's on the key (no help) but it might also be on the lock. Mine is something like 752.
If you can get the lock number, then check the archives under 'key' in the subject. Lots of keymakers there.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- ejshotgun
- RetroRiceRocketRider
Re: no key???
23 Feb 2006 12:03
To be honest, it would be a lot cheaper to just have a locksmith make a new key.
A new lockset (IF it's still available from Kawi) would probably cost you about $100 or more!
And trying to find a complete set on eBay is near impossible.
One thing you might want to try first is this:
Assuming all the locks are the originals and use the same key (actually, almost any key will open the gas cap lock on the older Kawis), remove any one of those locks and you will find a number stamped into it somewhere.
It should be a 3-digit number, and is the key code number for the pre-cut key to fit that lock(s).
Best bet is to check with an older Kawi dealership, as they'd be more apt to have some of the older pre-cut keys still in stock.
I think they cost about $5 or $6 each.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- rstnick
Re: no key???
23 Feb 2006 12:26
Locksmiths are great people! I should know, I am one.
If the locks are not damaged, it may be easy to have a key made from the code number. There usually is a code number on the Ignition Cylinder somewhere. On older bikes it was in plain site for everyone to see, next to the keyhole. The manufactureres finally got smart and started to put the code number on the back or side so you can't see it by glancing. Check for the number and with a Locksmith in your area. If you can't find anyone, I may be able to help you.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- oldcuda68
Re: no key???
23 Feb 2006 16:13
I agree with Rob. He made my keys for my switch. It works well. Just send him the switch an he will come through!!!!!
Mark
Mark
1980 KZ750 LTD
1984 Honda GL1200 Interstate
Too many other toys to mention
- hydrolazer
Re: no key???
23 Feb 2006 18:31
i went to the local lock jock and gave them my key number got a new key and keychain for $2.95...it worked perfect
\'79 kaw 1000 ltd
- crd
Re: no key???
21 Mar 2006 10:27
Just bought an 82 KZ250 project/salvage bike. P.O. had had papers and keys stolen during a house burglary. Bike's in pretty good shape, and I do hope to make a runner out of it. Am taking steps to retitle the bike, but I'd like to figure out the key issue.
I understand from searching the forum that the gas tank "lock" is probably not a lock, per se, but will work with pretty much whatever the ignition key is.
So, for the '82 KZ250, I need to find a three-digit key number on the ignition? And once I find that number, there should be a pre-made key that will fit, and some locksmiths and/or dealers may have that key? Please let me know if I've got it right.
Thanks,
Chris
Thanks,
Chris
- rstnick
Re: no key???
21 Mar 2006 10:51
You are right, in that the code number should be on the back or side of the Ignition lock. A dealer may have pre made keys, where as a Locksmith will cut a key using the code info.
Your code should fit in one of the series below:
Kawasaki Key Code Series
170-174
175-195
176K-250K
251K-325K
3101-3150
3201-3250
326K-400K
401-470
701-720
706-710
751-795
8001-9000
801-845
901-925
A00-A99
B8001-B9000
E8001-E9000
G1-G35
KZ5001-KZ6000
N1-N35
RVS101-RVS499
Z5001-Z6000
Post edited by: rstnick, at: 2006/03/21 13:53
170-174
175-195
176K-250K
251K-325K
3101-3150
3201-3250
326K-400K
401-470
701-720
706-710
751-795
8001-9000
801-845
901-925
A00-A99
B8001-B9000
E8001-E9000
G1-G35
KZ5001-KZ6000
N1-N35
RVS101-RVS499
Z5001-Z6000
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- crd
