What stator will work?
- OnkelB
Re: What stator will work?
23 Jan 2009 03:56 - 23 Jan 2009 05:47
Lou, I'm pretty certain that all the 650 cranks are the same so the permanent magnet rotors should fit the 77 - I have a 77 engine out of the frame and a spare 79 rotor so I can find out for sure.
As for the rotor/stator setup I'm running a 3-phase Electrex stator with the 79 D rotor/flywheel (originally meant for a 1-phase setup) and so far it seems to work perfectly well.
Oh yeah, RD 350 was my first (legal) motorcycle, had lots of fun on that one.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 23 Jan 2009 05:47 by OnkelB.
- RonKZ650
23 Jan 2009 06:42
The rotors will fit to the crank. The problem is the 78 and later covers and stators all look basically the same. Try to fit a different model stator to a cover it will not fit many times. They come in different sizes of course only a couple mm variation, but a couple mm is enough where the stator can't be fitted to a non matching model's cover. So I hope both the cover and stator are for the same model Kawasaki here or good chance they will not mate up.
- Snakebyte
23 Jan 2009 09:57
Acording to the seller they are a match. The two peices are off the same bike. The stator is a three wire so it will work with the stock wiring harness off the 81 550 A1, that is on my bike now.
now if I could just get rid of the spagetti
- Snakebyte
- OnkelB
23 Jan 2009 12:35
Wow, that's a lot of wires, good luck. I managed to boil mine down to this plus a couple of relays in the headlight bucket for an H4 conversion:
- OnkelB
- OnkelB
25 Jan 2009 08:41 - 25 Jan 2009 08:45
Last edit: 25 Jan 2009 08:45 by OnkelB.
- OnkelB
25 Jan 2009 08:42 - 25 Jan 2009 08:47
And one more:
Your reg/reg may not have the brown voltage sense wire, some do and some don't - if it's not there you obviously need not worry about it.
I'll post some more detailed info and pics later.
Last edit: 25 Jan 2009 08:47 by OnkelB.
- Snakebyte
25 Jan 2009 11:49
Thank you for the pics that will be helpful in the future.
- OnkelB
25 Jan 2009 13:47
No problem, like I said don't hesitate to ask if you need additional info or pics.
- loudhvx
25 Jan 2009 14:09
Some sweet lookin' work there OnkelB!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- OnkelB
25 Jan 2009 14:14
Thanks Lou, means a lot coming from you. Btw, let me take this opportunity to thank you in public, couldn't have made this work without your advice, greatly appreciated.
