- Thank you received: 2
KZ 1100 Starter Question
- KYKZ1100
18 Jan 2009 11:36 #258597
by KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
KZ 1100 Starter Question was created by KYKZ1100
When I bought my KZ1100A1 two years ago the starter cranked really slowly even with a new battery and even when jumped with a car battery. I bought a used starter on eBay and it worked fine. Then a few weeks ago, it all of a sudden started cranking really slowly. Did the starter go bad? If so, is it something that can be fixed by replacing the brushes or do I need a new starter?
1981 KZ1100A1 Shaft
2007 BMW R1200R
- MFolks
- Thank you received: 540
18 Jan 2009 12:41 #258600
by MFolks
Replied by MFolks on topic KZ 1100 Starter Question
The starter solenoid might be on it's last legs. Trace from the positive battery terminal and you should find it at the end of the heavy gauge cable. Check the terminations for corrosion or looseness.
If the teminations are clean and tight, see if you can put a screwdriver across the two heavy gauge wire terminals and see if the bike cranks. If it does this means the starter solenoid is bad and needs replacing.
www.denniskirk.com and www.jpcycles.com might sell replacement solenoids. If not, remove the solenoid and visit the local riding lawnmower shop and see what matches up. The shop solenoid might take a little modification but instead of $100 or so the cost might be under $20.00
- KYKZ1100
18 Jan 2009 14:14 #258620
by KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
Replied by KYKZ1100 on topic KZ 1100 Starter Question
Mfolks,
Thanks. Would a bad solenoid cause slow cranking? It still cranks but very slowly - not fast enough to start.
1981 KZ1100A1 Shaft
2007 BMW R1200R
- MFolks
18 Jan 2009 14:48 #258628
by MFolks
The solenoid is nothing more than a heavy duty relay(remote controlled switch) that has internal contacts that can corrode and reduce the starting current to the motor. Bypassing this will tell you if it's the soenoid or starter motor.
- Killbert
- Riding Vintage
18 Jan 2009 16:04 #258647
by Killbert
1982 Kawasaki KZ1100 Spectre D1
Looking for a sissy bar/back rest/luggage rack! PM ME!
Replied by Killbert on topic KZ 1100 Starter Question
I purchased a rebuilt starter and ruined it quickly with repeated starts on a semi-good battery. This burned out the brushes and looked at first to be the solenoid. I replaced the starter AND the battery, and the bike started like a champ. Using a car battery and jumper cables did not provide better starting compared to a good motorcycle battery. I even tried my Optima Red Top and some serious jumper cables. I'm convinced that the starter on these older motorcycles is just old technology and isn't very efficient. If the starter goes out again, I am going to retrofit a more modern starter in there.
Kellyn
Kellyn
