spark plug wires with dyna coils stupid question
- bigkzfan
- if grandpa had tits he"d be grandma, if
16 Jan 2009 16:21
can anyone enlighten me as to which spark plug wire goes to what cylinder after dyna 3ohm coil install on my 1982 kz1000 j model..ty in advance..ps i am in the process of stage 3 jet kit new coils...already done wg coil mod last summer..
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
- Snakebyte
Re: spark plug wires with dyna coils stupid question
16 Jan 2009 17:02 - 16 Jan 2009 17:03
One coil goes to 1-3 the other too 2-4. Coil fires two cylinders at once. When it fires 1 on compresion the 3 is on exhaust, and vice versa.
Last edit: 16 Jan 2009 17:03 by Snakebyte.
- Old Man Rock
16 Jan 2009 17:15
Top right image...
The left side pickup is for cylinders 1 &* 4 to the coil that is installed on the left side under the tank...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MFolks
16 Jan 2009 18:05
The factory shop manual on my 82 GPZ1100 B2 shows the left coil firing plugs 1&4 and the right coil 2&3 .
This is numbered left to right while sitting on the seat.
- keith1
16 Jan 2009 18:08
OMR,
you are undoubtedly the picure posting king!!!! good info, great pics......keith...
- bigkzfan
16 Jan 2009 18:16
ok that makes sense, but does it matter on each coil which lead goes to what cylinder? say left coil one and three does it matter what lead off the coil should go to each cylinder the front lead off the coil or the back lead off the coil..thank you guys so much for your help
- MFolks
16 Jan 2009 18:35
Makes no matter as long as the left coil goes to 1&4 and right coil 2&3.
- bigkzfan
16 Jan 2009 18:39
excellent thank you very much...i decided to put stage 3 kit, pod filters, new dyna coils, handelbars,and valve cover gasket..like johnny cash one piece at a time...lol
16 Jan 2009 18:45 - 16 Jan 2009 18:47
bigkzfan wrote:
Both leads fire simultaneously from a coil with dual plug wires.
Be sure both plug wires from one coil attach to spark plugs for outside cylinders #1 and #4. And that both plug wires from the other coil attach to spark plugs for inside cylinders #2 and #3.
Coils on the large fours are usually mounted with the left-side coil firing both outside cylinders and the right-side coil firing both inside cylinders.
Left-side means shift-lever side of bike. Right-side means rear brake pedal side of bike.
Good Luck!
Good Luck!
Last edit: 16 Jan 2009 18:47 by Patton.
