Dyna S ignition upgrade/igniter question
- fredgarvin42
10 Jan 2009 14:09
I have a 1980 LTD 1000 and am considering getting the Dyna S ignition upgrade with the green 3 ohm coils. My bike currently has some type of electronic ignition and had 1.8 ohm coils. I replaced the coils since one of the was open on the secondary with 2.7 coils and it ran for about a day. Now it appears the igniter is gone (no voltage at the coils. I have power but no ground). I've been trying to get the scooter running on the cheap but I'm running out of options
If I get the Dyna S setup does that eliminate the need for the igniter?
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
1985 Ninja 600
1984 YZ 490
Austin,TX
- timebomb33
Re: Dyna S ignition upgrade/igniter question
10 Jan 2009 14:11
yes the dyna s is self contained get the dyna coil's and maybe a rev limiter as well cheap insurance.
I THINK MY POWERBAND BROKE
- saxjonz
- KawboyZ
10 Jan 2009 16:59
Yup, you can't even mess with the timing on the 80 with stock plate. At the same time maybe you should pick up a 79 timing advancer so you can time both 1&3 as well as 2&4 as with the 80 it doesn't have the marks for both. Then you can fine tune the timing.
I replaced the stock ignition on my bike with the dyna s and removed the coils, igniter and ignition plate along with the advancer. Replaced that with the 79. Or if you prefer to stay stock my stuff was working just fine when removed.
79 LTD B3
- bill_wilcox100
10 Jan 2009 18:35 - 11 Jan 2009 07:10
fg42, if you are satisfied that your OEM Igniter has really failed then consider the Dyna S.
Kawasaki shows an LTD listed as a KZ1000-B4 in 1980 and it was OEM with an Igniter:
Kawasaki Ignition Link
This is where I got mine:
Z1 Ent Ignition Link
You may need a different model:
"Dyna-S Electronic Ignition DS2-1 - Kawasaki Z1 KZ900 KZ1000"
This is how I installed mine. Check closely for your model. If in doubt, call them:
Dyna S Install Link
Note that this diagram also includes the WG Coil Repowering Modification on a separate fuse circuit to help with troubleshooting/maintenance. You need WG Mod either way and it's under $10 USD. Don't ask how I found out. :blush:
Best of success.
PS
Add your year, model and location to your signature. It really helps in getting the best responses and it's considered real friendly too.
Bill
Dyna S Install Link
Best of success.
PS
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 11 Jan 2009 07:10 by bill_wilcox100.
- steell
11 Jan 2009 06:49
fredgarvin42 wrote:
You're speaking my language (cheap)
It's a whole lot cheaper to make your own igniter, and if it ever goes bad you can repair it or make another one.
www.geocities.com/loudgpz/GPZgmHEImod.html
Loudhvx's website.
Loudhvx's website.
- fredgarvin42
11 Jan 2009 20:04
Thanks everyone!!! Yall rock!
Gonna order the goodies tomorrow morning. The H.E.I tip is a REAL good one but I'm going to go ahead and get on the ramen diet for the month and get the Dyna S, coils, wires, plugs. I will also do the WG wiring trick as well.
I took the tip of adding my bike info, location, etc. I'll also get a pic up there as soon as I get it put back together.
Peace
Peace
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
1985 Ninja 600
1984 YZ 490
Austin,TX
- timebomb33
11 Jan 2009 20:13
eat ramen for another 2 weeks and pick-up the drl300 rev limiter from dyna as well. it keeps it from over reving and could save an engine if you ride hard like i do.
- timebomb33
11 Jan 2009 20:15 - 11 Jan 2009 20:18
also i'm going to try that hei moduale trick on one of my projects that looks very cool and cheap.thanks for turning me on to that. wish i could spell
Last edit: 11 Jan 2009 20:18 by timebomb33.
- bill_wilcox100
11 Jan 2009 21:32 - 11 Jan 2009 21:35
fg42, don't need to wait until the project is done to post pic's. The journey is everything. Consider before, during and after Avatar shots.
As you can see from my Avatar, I am a COOOOOLD storage advocate. :laugh:
Best of success.
Best of success.
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 11 Jan 2009 21:35 by bill_wilcox100.
- Sandy
- Fly High,Tony
12 Jan 2009 08:01
Go for the "Dyna 2000" kit.It has a built-in rev limiter,plus other goodies.You can set the timing with the bike not running.
1977 KZ1000 A-1
- fredgarvin42
16 Jan 2009 10:03
Thanks for all the killer feedback and info!!!
I've installed the Dyna-S system with the green coils. Just need to make up the wires. Well, coulda been too much spaten optimator that made me to lazy to finish the plug wires. Going to wrap it up today or tomorrow and will post the results. I will also be doing the wiring fix too but not this weekend.
I may get to upgrade my meal plan from ramen to grilled cheese and V8 next Friday. YAY!
More to come...
More to come...
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
1985 Ninja 600
1984 YZ 490
Austin,TX
- fredgarvin42
19 Jan 2009 10:28
All good! Finished the wires and rode it all weekend. It rides great and the sputtering when cold problem also disappeared. It is a very well mannered scooter now! JOY!!!
Next. Fix an oil leak, ride, fix the starter, get a header, ride, etc...
Thanks for all your help!
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
1985 Ninja 600
1984 YZ 490
Austin,TX
