Rectifier/Regulator Problem?!?
- TeK9iNe
- What did you do!?!
07 Jan 2009 08:37
Hey all its been a while...
Just working on my bike right now. Its in pieces everywhere around here!
I've got a strange sort of problem... i think.
When I start my bike it starts fine and warms up normally.
It then idles at my set 1200rpm after bout 4-5mins.
If I unplug my regulator/rectifier unit and start the bike it starts like its being jumped! Warms up quicker, and once warm, it idles at aroung 16rpm??!!??
Wha?? Is this normal?
The regulator rectifier works fine, I've checked it numerous times. It charges the battery fine and the batt doesnt get hot. it maintains a constant 12.34V when everythings off, when at 4000rpm its at 14.24V.
I had my shop frind test it on an osci-scope - OK.
New alt. Voltage from alt is good and not grounding- all three wires. I have the wiredgeorge coil mod - exact as spec'd.
Cheers!!
Cheers!!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kawickrice
Re: Rectifier/Regulator Problem?!?
07 Jan 2009 08:42
If your charging system is working why unplug the rectifier? Am I missing something.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- SPARKY47
- 1980 KZ500 B2
07 Jan 2009 08:58 - 07 Jan 2009 09:05
16 rpm?
How?
If you mean 1600 then there's an easy explanation....
In generating elec, the power comes from the engine, remove that load,rpm goes up.
How?
1980 KZ500 B2
Last edit: 07 Jan 2009 09:05 by SPARKY47.
- TeK9iNe
22 Jan 2009 23:06 - 22 Jan 2009 23:08
Yeah I meant 1600rpm. Had the Rect/reg unplugged for something and just discoverd this...
Would the engine output drop that much, just from power generation?
Sounds fishy... I replaced the stator with a used one from another bike a little while back. Its been charging and keeping Volts proper.
I dont know... anymore ideas? :blink:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 22 Jan 2009 23:08 by TeK9iNe.
- steell
23 Jan 2009 01:39Would the engine output drop that much, just from power generation?
Yes.
That's one of the reasons that cars have Idle Air Controllers, step the idle back up when electrical load kicks in.
Takes about 3 hp to drive that alternator at full output.
- TeK9iNe
26 Jan 2009 08:33
A HA! Thank you.
So no wonder it drops the rpm's so much at idle...
Cheers buds!
Cheers buds!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
