no gauge lights? 81 750ltd
- MFolks
Re: no gauge lights? 81 750ltd
07 Jan 2009 17:58
Get a multimeter so continuity and voltage checks can be performed. The taillight circuit may be seperate from the instrument bulb circuit.
The only way to see is with the wiring diagram. Check the fuses and fuse clips for corrosion. These type of glass fuses can fail internally and look good. The only good way is to pull them one at a time and with the multimeter or self powered continuity light see if the fuse is electriclly good.
- kztee
- TeeRoy
07 Jan 2009 18:41
With mine the fuse blows. I put in a new one (fuse marked 'rear') and the tail lights and guage lights work for a while. Then the fuse blows again. Seems to me I have a short somewhere but where and how do I start to narrow it down?
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- MFolks
07 Jan 2009 19:18
Make up a 12 volt light with some small alligator clips and wire(Radio Shack stuff) and put it in circuit where the fuse goes. If the light comes on you have a short. This will envolve disconnecting the circuits until the light goes out. This way the process of elimination is used to locate shorts. Possibly a wire rubbing through the insulation to the frame or an adjacent wire in the harness is the cause of blowing fuses.
- MFolks
08 Jan 2009 12:31
To amend my above post: a good way to check for a short is to make up a 12 volt light using wire and alligator clips from Radio Shack.
Disconnect the positive battery lead, put the new test light between the positive battey terminal and the positive battery cable and turn on the ignition but do not start the bike. The light will burn out if the starter is used.
If there is a short the light will come on. Disconnect the circuits one at a time to find out where the short is. any place the harness is flexed or rubs the frame is suspect causing the fuse(s) to blow.
- bountyhunter
08 Jan 2009 13:22
keith1 wrote:
Nope, they can't do that. The running lights are wired from an accesory terminal bus line off the ignition switch.kztee wrote:Do you have a tail light? On my '80 750 LTD I have a blown fuse, caused by a yet to be found short, that causes me to loose gauge lights and tail light (the brake light still works).
same disfunction on my 78 1000 ltd...no tach lite no speedo light, no running lite.brake lite is fine and everything else works...i have guage bulbs....i m just wondering out loud if i change them, will they help restore a circuit and make my
running lite work?....
- bountyhunter
08 Jan 2009 13:24
MFolks wrote:
Any glass tube fuse more than a couple of years old needs to be chucked and replaced.Get a multimeter so continuity and voltage checks can be performed. The taillight circuit may be seperate from the instrument bulb circuit.
- bountyhunter
08 Jan 2009 13:26
MFolks wrote:
radio Shack also sells a cheap 12V buzzer you can use for troublehooting like this so you don't have to keep watching for the light.
- kanexx
31 Oct 2024 05:14
I am also having that same problem on my 80 750 ltd. Everything else is OK besides tail light and gauges don't light up
31 Oct 2024 06:52I am also having that same problem on my 80 750 ltd. Everything else is OK besides tail light and gauges don't light up
- kanexx
04 Nov 2024 22:18
Thank you for that info, will be checking that out tomorrow along with the hanging idle, both which have dumbfounded me. It is my first street bike. I am not a whiz on the electrical part at all! Thanks again
Kane.
Kane.
