right side handle bar controls
  • Buda
  • Buda's Avatar Topic Author
21 Dec 2008 20:58 - 21 Dec 2008 21:18
#254040
I was looking around on ebay and found the controls (start and kill button) and the dude was asking $250 that cant be right. Am I wrong?
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 21 Dec 2008 21:18 by Buda.
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: right side handle bar controls
21 Dec 2008 21:10
#254042
For your 82 1000 right? 250 bucks is out of this world. I would keep lookin for sure.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • MFolks
  • MFolks's Avatar
21 Dec 2008 21:10
#254043
Have you looked at www.redlinecycle.com , www.vintagecyclepart.com , and www.sudco.com $250 is a really high price for this control pod.
  • Buda
21 Dec 2008 21:17
#254045
I was hoping it was way high because both controls on my bike are rough.
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
21 Dec 2008 21:40
#254047
Here...
Right hand controlhttp://www.z1enterprises.com/detail.aspx?ID=2040
Left handhttp://www.z1enterprises.com/detail.aspx?ID=2041
1977 KZ1000 A-1
  • HerrDeacon
  • HerrDeacon's Avatar
22 Dec 2008 03:22
#254056
Thanks
You mean just cosmetically rough? You can repaint them and they come out looking good. I've done it and it's not that hard. Look like new now.
  • Buda
22 Dec 2008 08:52
#254109
Sandy wrote:
Here...
These are for a older bike but if they would work I dont care. Also can the controls be "rebuilt" inside the switchs feel gritty hard to move.
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • tjhiggin
  • tjhiggin's Avatar
22 Dec 2008 11:21
#254131
Yes they can be reworked but you have to be careful. Sand the contact points with some high-grit paper, apply some dielectric grease to the contacts, lube the points where the switches rotate, and you should be good to go. I did this on my CB550 and worked fine.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
  • Buda
22 Dec 2008 11:25
#254133
cool
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • wiredgeorge
  • wiredgeorge's Avatar
24 Dec 2008 07:00
#254428
The switches that Sandy pointed out won't work without a lot of modification. The older switches have a headlight on/off feature that you would have to run wires to connect. The rest of the wires will not connect to the main harness or to the connector inside the headlight shell directly. You will have to cut off the connector on the new switch and get a matching Z1 connector and then correctly pin the new connector to mate with the connector on the harness. It isn't a trivial job. It would be better to watch eBay and find the correct switchgear for your bike, clean up contacts and the switch and use the correct switch, in my opinion.
