KZ550 blinker problems
- mehall2
14 Dec 2008 17:49
Need some help from someone good with lighting. All 4 turn signal lights come on as running lights which I believe is normal. When initiating a right or left turn signal, the respective front/back lights get brighter in the direction I indicate, but they don't flash. I had an order into Z1enterprises already so I just added a flasher unit since it was really cheap. I'm hoping that does the trick. If not, I'm only out $2.50.
'81 KZ550 LTD
'07 Yamaha FZ6
'07 Yamaha FZ6
- bountyhunter
Re: KZ550 blinker problems
14 Dec 2008 17:59
With both sides doing that, I'd suspect the flasher unit first.
- Locozuna
14 Dec 2008 18:42
My 550ltd had running lights in front but not in back. Blinkers all worked tho.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- bountyhunter
14 Dec 2008 22:29
Stock bikes usually do have only dual filament running/turn signal bulbs in front to create the amber running lights. A lot of people add the dual filament bulbs to the rears to get running lights there too.
- tjhiggin
15 Dec 2008 12:33
The bike originally came with a bi-metallic flasher. The $2.50 flasher is also likely bi-metallic (the Z1 web site doesn't specify). The replacement will probably work fine, but in the event that it does not, I recommend an all-electronic solid state flasher. They go for $7-$10 at your local auto parts store.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
- Vter Bob
15 Dec 2008 14:48
If all four amber lights light up and there hasn't been a modification made to the system I'd start checking wiring. I agree with the suggestion to use an electronic flasher unit in place of the old style and if all else fails.... you did check the blinker fluid, right? :woohoo:
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- Old Man Rock
15 Dec 2008 17:14you did check the blinker fluid, right?
You're pure evil demon spawn... hahahahaha :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- mehall2
15 Dec 2008 17:33
Thanks for the advice here. My flasher unit should be in this week from Z1.
'81 KZ550 LTD
'07 Yamaha FZ6
'07 Yamaha FZ6
- PLUMMEN
15 Dec 2008 21:31
