Correct Lighting Question - 79 SR650
- rjd4949
28 Nov 2008 08:16
Question folks - When I turn on the lights; actually when I turn on the key - there is no light switch, I get the rear ambers on with the headlight and taillight. I don't get the front ambers. Is that by design or should they come on as well? Brake light, individual turn signals and 4-ways all working as they should. Single-filament "1073" in the rear; double-filament "1034" up front. My book is no help, and I can't find, on-line, specs for what the correct bulbs should nor could Kawasaki dealer help - too old, I guess).
"...all we need is a fast machine."
Re: Correct Lighting Question - 79 SR650
28 Nov 2008 08:23
rjd4949 wrote:
Perhaps running light filaments are burnt out in both front bulbs.
Or loose connector in wiring to front running lights.
Good Luck!
... get the rear ambers on with the headlight and taillight. I don't get the front ambers... double-filament "1034" up front....
Good Luck!
28 Nov 2008 08:29 - 28 Nov 2008 08:33
If not already checked, here are a couple of the wiring diagrams available under "KZ Information" sub-menu "Filebase"
Link to wiring diagram.
Wiring diagram
Wiring diagram
Last edit: 28 Nov 2008 08:33 by Patton.
28 Nov 2008 08:31
Hello Rory and WELCOME to KZr forum! We're glad you're here!
- MFolks
28 Nov 2008 10:47
I'd remove all four turn signal lenses and examine each bulb. From the factory the front turn signals were dual filament for turn and running lights while the rear ones were just for turning indicators.
The previous owner may have switched front and back signals for what ever reason.
The headlight circuit is controlled(I think) by a reserve lighting system that turns on the headlight after engine start. It also provides the high beam at reduced voltage in case the low beam burns out during a drive allowing you to get home still having a headlight.
- rjd4949
28 Nov 2008 11:41
Thanks, Mike - You nailed it. I actually wrote that post wrong. I do have front running lights, no rear. So, as you say, this must be by design. It didn't make sense that the previous would have changed anything. As the story goes, he bought it new (his parents did) in June, 1979. Rode it for about 800 miles, crash
ed and parked it. I picked it up this past summer. Yep - 814 verified miles. Wanna see a pic?
Thanks, Patton, for the welcome and advise.
- fixer5000
28 Nov 2008 13:14
nice bike there...correct on front running lights and not in the rears. my 78 is the same stock
1978 kz650b pretty much stock
massachusetts
massachusetts
- rstnick
28 Nov 2008 19:55
Nice find indeed!
Under 1000 miles, WOW.
I had front signals (3 wire dual filament bulbs) put on the back of my bike some years back so all 4 signals were running lights. Sure helps to be seen.
Just gotta run the third wire from the front signals to the back.
Now none of my signals are running lights as I've changed the signals since.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- bountyhunter
29 Nov 2008 13:51
rjd4949 wrote:
That's backwards: the front headlight, front amber and rear tail should come on with the key if it is wired stock. The rear ambers are single element bulbs, turn signal only. I changed mine to dual filaments so I have running lights at all four corners now.Question folks - When I turn on the lights; actually when I turn on the key - there is no light switch, I get the rear ambers on with the headlight and taillight. ).
- bountyhunter
29 Nov 2008 13:54
rjd4949 wrote:
Here's why: the headlight has no visibilty at right angle to the bike so running lights are needed. The rear brake light has "side view" on it so it can be seen from the sides, so running lights were not used.Thanks, Mike - You nailed it. I actually wrote that post wrong. I do have front running lights, no rear. So, as you say, this must be by design. .
- rjd4949
30 Nov 2008 08:14
Now that makes sense. I like the idea of wiring the rear for running lghts. I'm all about visibility.
