dyna coils question
  • jimmybon
  • jimmybon's Avatar Topic Author
dyna coils question
19 Nov 2008 13:22
#248361
I ordered a set of dyna coils 3ohms for my gpz750 engine
the sender sent 5ohms coils,
question is can i use these 5ohms coils with my engine which has standard ignition pickups and igniter?
if not could I use them on my Z1900 with std points setup?:unsure:
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • MFolks
  • MFolks's Avatar
Re: dyna coils question
19 Nov 2008 15:33
#248377
My understanding is you can use greater than 3 ohms but not less than. Something about possible overheating of the coils(could be wrong).
  • bountyhunter
  • bountyhunter's Avatar
19 Nov 2008 19:02 - 19 Nov 2008 19:02
#248404
No danger going up in resistance, only down. I believe the stock coils for yours are 4 Ohms and Z1 sells OEM replacements if you want 4 Ohm coils. A 5 Ohm coil should work fine.
Last edit: 19 Nov 2008 19:02 by bountyhunter.
  • jimmybon
19 Nov 2008 20:45
#248436
OK, I'll give them a go.
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • Old Man Rock
  • Old Man Rock's Avatar
20 Nov 2008 03:43 - 20 Nov 2008 03:46
#248461
As others mentioned, as long as they are over 3 ohms (within reason) you should be ok...
Question, why not send them back and get what you ordered?
NOTE: Unless you got them off e-bay or something as such...
Granted, the image is for the KZ900... But look at the last paragraph.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 20 Nov 2008 03:46 by Old Man Rock.
  • loudhvx
  • loudhvx's Avatar
20 Nov 2008 10:19
#248510
Points coils were about 4 ohms. Higher is safe, but may give weaker spark. 3 ohms will work but will shorten the life of the points somewhat. Dwell is about 180 degrees with points.
Kaw factory electronic-ignition coils were about 2.5 ohms. 3 ohms works well with it. Any higher and you start to get a weaker spark. This is because the dwell is reduced to only about 120 degrees with the Kaw factory electronic-ignition (which allows useage of hotter coils).
Dyna S ignition recommends 3 ohms or higher coils. The dwell on the Dyna S is nearly 360 degrees, so new 5 ohm coils should work fine. 3 ohms may make more spark, but should only really make a difference at higher RPMs on a good, well-jetted motor.
  • eaglecrash2
  • eaglecrash2's Avatar
20 Nov 2008 19:05
#248575
The resistance you mentioned here is of course the primary winding. What about the resistance of the secondary winding? Isn't the strength of the sparks the results of the difference between the windings?
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
  • loudhvx
  • loudhvx's Avatar
20 Nov 2008 19:59
#248584
You are correct, the measurments are only of the primary side resistance, but coils are similar enough for motorcycles that we can take some liberties with judging them based on primary resistance. Typically they are, if I recall, generally in the 100 to 1 ratio for the windings. Also, the higher the resistnace of the primaries, the higher their inductance is, very roughly speaking. So we can assume higher resistance coils will generally also require longer dwell to fully charge.
Because the current on the secondary side is low, we don't worry too much about the resistance there. That's why resistor plugs, caps, or wires can be used without decreasing spark by too much. We measure the secondary resistance just to look for defects from one coil to another, but I don't know of a correlation between performance and secondary resistance. (There may be one, but I've never heard much discussion of it.)
  • bountyhunter
21 Nov 2008 15:35 - 21 Nov 2008 15:36
#248690
NO, it's actually a result of how much energy is stored in the primary winding and then dumped out of the secondary when the primary winding "breaks" when the points open. The design topology is called "flyback" in the parlance of magnetic converter design. The basic principle is the primary winding stores energy while current flows in the primary and then that energy dumps from the secondary when the primary opens. The primary and secondary couple because they are a transformer, he secondary voltage is stepped up greatly by the transformer turns ratio. The actual energy delivered is dependent on an assortment of variables.
Last edit: 21 Nov 2008 15:36 by bountyhunter.
