Plug gap with dyna
  • eddiem
  • eddiem's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #63
Plug gap with dyna
13 Nov 2008 09:11 - 13 Nov 2008 09:11
#247193
Seems like I read somewhere and it might have been here that you open the gap more when you use the dyna ign.
Do you run a diff gap on the plugs when you go to the dyna ign.?
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Last edit: 13 Nov 2008 09:11 by eddiem.
  • BSKZ650
  • BSKZ650's Avatar
Re: Plug gap with dyna
13 Nov 2008 09:38
#247196
some may say to run a wider gap with solid state ignition, I dont, I gap the plugs to the factory spec.
77 ltd1000, current rider
76 kz900, just waiting
  • MFolks
  • MFolks's Avatar
13 Nov 2008 10:49
#247205
On my old 77 KZ1000 had points and I wasn't crazy about the maintenance. I purchased what was then a "hot" ignition system called a "Gerex", I believe the spark was so intense the plugs were gapped for really large openings and it ran well.
any new sparkplugs had to have the ground terminal straightened out and then bent for 0.65 clearance.
  • RonKZ650
  • RonKZ650's Avatar
13 Nov 2008 13:09
#247227
I don't think there's any need to go wild with the gap. I just take them out of the box, if the tip isn't bent normally they about .032" which works fine.
  • 6leafclover
  • 6leafclover's Avatar
13 Nov 2008 13:38
#247230
hey theres a tip for that from greg cope on his page about tuning i think its .026 for a dyna-s but heres the link www.aperaceparts.com/COPE.HTML
1979 KZ1000-E1/ST
Madison, IN
  • bill_wilcox100
  • bill_wilcox100's Avatar
13 Nov 2008 14:51 - 13 Nov 2008 14:52
#247235
My Clymer Manual says ("stock" Gap with 5 Ohm Coils):
SPARK PLUGS... stock Gap 0.028-0.032 in. (0.7-0.8 mm).
KZ650.INFO says ("with Dyna" Gap):
- Replace points unit with a Dyna S or Dyna III electronic ignition or equivalent.
- Fit Dyna coils (3.0 ohms) and wires, gap spark plugs to 0.032–0.035 in.
Dynatek site (for HD's only) says:
What should I set my spark plug gaps to?
The gap settings listed below can be used as a starting point to obtain satisfactory performance with our ignition system. Any benefit from running larger or smaller gaps will need to be determined by experimenting with your particular engine combination.
Single Fire - Single Plug: .035 to .040
Single Fire - Dual Plug: .022 to .025
Dual Fire - Single Plug: .035 to .040
Dual Fire - Dual Plug: .035 to .040 - When wired so each coil fires a plug in each cylinder.
Dynatek site (for Metric bikes) says:
- ... moot.
I read the above as saying:
- stock is max. 0.0320 in. (0.800 mm)
- w/Dynatek is 0.0325 in. (0.825 mm)
So I conclude that the Plug Gap can stay OEM or if you're really picky add 0.0055 in. (0.025 mm).
Anyone come up with something else?
Best of success. :)
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 13 Nov 2008 14:52 by bill_wilcox100.
  • gane
  • gane's Avatar
13 Nov 2008 18:05
#247250
I've a old dyna s, coupled w/andrews "blue goose" coils, I forget the exact spec's but think they snap at @ 60kv. I run .036 gaps simply because I can figuring a larger spark should provide a better burn. But frankly have noticed no difference in running.G
[img][/img] 1977 KZ1000A1
  • timebomb33
  • timebomb33's Avatar
13 Nov 2008 19:24
#247266
i run .032 on my dyna 3 .028 with my dyna s and.018 with my dyna 4000sp drag race ignition
I THINK MY POWERBAND BROKE
  • eddiem
13 Nov 2008 19:42
#247269
Thanks everybody I went with .032
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
