Acewell Speedometer Kawasaki adapter
  • KawiConvert
  • KawiConvert's Avatar Topic Author
11 Nov 2008 19:25
#246939
Just started installing mine on my KZ650 and found that the adapter that connects into the wheel drive doesn't fit. I was able to swap the screw on holder from the stock cable with a little sanding and very little work. Just thought I would warn others that they may take some work to get it to fit if you buy the Acewell and don't want to use the magnet pickup.
Sorry, no pics of it installed yet as I am still building a bridge to attach it to.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Acewell Speedometer Kawasaki adapter
12 Nov 2008 06:45
#247028
Which model did you go with?
I've been looking at the 2802-AB (Black Only) for they don't offer here in the States the Billet Aluminum any longer. So I figured for $120, buy the black, strip the paint and buff it out.
Same time, I've already contacted ElectroSport and the new 4000 model is coming out after the first of the year...
Analog RPM meter plus you get volatge read outs....
www.electrosport.com/street/speedometers-series-4000.php
Please keep us posted on how the unit operates. Speed measuremnt seems to be good enough but there's considerable amount of posts regarding the RPM accuracies.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • KawiConvert
12 Nov 2008 18:07
#247124
I wonder if the RPM's are an issue because the KZ fires every stroke like a 2-stroke does. My other guess would be due to interference as the sensor wire is not shielded at all. Once I get it on and all ready to go I will post a follow-up.
  • Old Man Rock
20 Nov 2008 18:10
#248553
Kawi... Well, hows the Acewell speedo working out?
Which unit did you go with?
Any images you can share?
Speed / tach accurate?
Share the news damn it... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • KawiConvert
20 Nov 2008 18:17
#248555
OMR
Bike isn't done yet, but I'll toss you a bone. Here is the installed look. I am working on the wires, headlight mount, and the seat. Almost done.
  • Old Man Rock
20 Nov 2008 18:20
#248556
Have any side profile shots installed?
I was trying to get the billet aluminum but no longer available. You go with Black?
Which model is it?
You're killing me here... hahahaha...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • KawiConvert
20 Nov 2008 23:23 - 20 Nov 2008 23:24
#248606
Ok, don't remember the model off the top of my head, probably the 2853 type model in chrome. I have all the dummy lights, tach, speed, and fuel (this will be tricky because the fuel float in my tank doesn't have quite the range needed so I have to see if I can add some resistors to get the range corrected. Anyways, as you can see from the picture, the way I have it mounted would not interfere with the stock headlight setup. I am moving my headlight down and back so clearance could be an issue if I moved the speedo down as well, but I think I will leave it where it is at for the time being (probably). Anyways, here are two pictures from the side to show its position. It really is a clean little unit that looks like it will work and display well and tuck out of the way. One thing though, the mount is pretty much permanent so you are stuck with a one bolt mount that is roughly a 5/16" (sorry, no metric today) diameter hole. I am trying to come up with a way to take care of that, but nothing comes to mind so far unless I get some time on a mill :).
Last edit: 20 Nov 2008 23:24 by KawiConvert.
  • Old Man Rock
21 Nov 2008 04:32
#248617
Sweet, thanks...
I have been wondering how big the enclosure was and how it would look installed, now I know. And how the hell did you find the chrome one... Good for you.
I'm hoping the new 4000 series will be available in Billet Aluminum and is approximately the same size, truly doesn't matter though for as you did, I will fab a mount. Plus this new series also displays voltage measurements...
As for the digital speedo, it is required in my project for there isn't a front sending unit on the ZX636 front forks/hub.
Once all polished up, that is going to look really nice.
Thanks again,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
