battery dies
- shui3000
battery dies
03 Nov 2008 01:02
So, I was working on my bike, and forgot to turn the key to off, so the headlight drained the battery. I had to jump start the bike.
Now, I have to jump start it every time after I've parked it overnight. Also, it won't start with the choke open anymore. Is this related with the battery issue? Not enough electricity?
What should I do (I'm a newb).
I forgot to add, it's an 81 kz440 ltd-a2
- PLUMMEN
Re: battery dies
03 Nov 2008 05:22
checkthe water in your battery,maybe have it load tested to see if its any good.
- Old Man Rock
Re: battery dies
03 Nov 2008 07:01
As Plummen replied, could be just a faulty battery.
I don;t know the 440 series electronics so please excuse if speaking out of turn here...
Are the battery terminals all coroded (battery acid paste)?
Another way to test, disconnect the (+) off the battery and after sitting all night, re-connect and see if she still holds a charge.
Shorted diode somewhere in rectifier, in-line, switch to power etc... for something is draining the battery.
Is the charging ciruit itself working?
DVM with bike running should be ~ 13-14.5Vdc.
DVM current measurement, with bike off for parked overnight, is current being measured?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- BSKZ650
Re: battery dies
03 Nov 2008 07:43
did you charge the battery on a charger, like over nite,, if you are trying to ride it to charge, you may not be getting a full charge in the batery to start with
77 ltd1000, current rider
76 kz900, just waiting
- shui3000
Re: battery dies
03 Nov 2008 08:16
yeah, i was just trying to charge it with the bike... i guess that the problem?
How about the choke issue, could that be related to the battery?
Re: battery dies
03 Nov 2008 09:19 - 03 Nov 2008 09:32
shui3000 wrote:
Imo, No.
Tip -- If the carb has an enrichener circuit (adds fuel mixture) as opposed to a true choke (reduces air intake), when first cranking up a cold engine and using the enrichener circuit by lifting the "choke" lever, do NOT even touch the throttle. With an enrichener circuit, the choke is designed to function with the throttle completely closed, and this would apply regardless of whether using kick starter or starter motor.
Good Luck!
... How about the choke issue, could that be related to the battery?
Imo, No.
Good Luck!
Last edit: 03 Nov 2008 09:32 by Patton.
