timing advance, lube?
  • thadley55
  • thadley55's Avatar Topic Author
  • TWO WEEKS!!!(Money Pit the movie)
29 Oct 2008 18:35
#244547
Helow, just jumped over from the engine forum to ask this simple question. What is the best thing to use to clean and the lube the timing advancer? I may have made a mistake. I cleaned it with carb cleaner:unsure: and then sprayed silicone on it. When I took my bike for a little hop around the corner she had NO power on the bottom end But once we were past the advance curve she ran like a champ!!:cheer: . I hope I didn't fry an o-ring (if it even has one?) or something on my advancer. I'm hoping it's just the cheap lube I have. Any input?
ThanksB)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
  • PLUMMEN
  • PLUMMEN's Avatar
Re: timing advance, lube?
29 Oct 2008 19:15
#244551
contact cleaner and a little dielectric grease,make sure they move freely.;)
  • JMKZHI
  • JMKZHI's Avatar
Re: .
29 Oct 2008 19:22 - 04 Dec 2008 09:40
#244554
del
Last edit: 04 Dec 2008 09:40 by JMKZHI.
  • RonKZ650
  • RonKZ650's Avatar
29 Oct 2008 19:45
#244562
You can use oil, grease, really anything. Silicon should even work. All that matters is it's not seized up. I haven't lubed mine for 40,000 miles. I checked it the other day and it's not stuck. All that matters.
  • timebomb33
  • timebomb33's Avatar
29 Oct 2008 19:51
#244563
i personaly like to use moly grease
I THINK MY POWERBAND BROKE
  • gane
  • gane's Avatar
29 Oct 2008 20:30
#244570
Thad, you don't mention what your' bike is, but centrifical advances are very similar regardless and easy to service.things to note are cam lobe wear, relation of lobe to backing plate prior to dis-assembly , and wear between cam lobe and pivot shaft. with advance unit in hand and springs removed, simply rotate lobe to center of travel and draw out. weights are staked to plate and remain in sittu, simply clean/free, lube and re-assemble.as noted nearly any lube will due, as there is little load applied and lots of surface area. tho I recommend something that will be low friction,doesn't stiffen w/age and hangs around without slinging onto points.I like Redline assy lube,tho white lithium, or mollidemm(cut w/engine oil to suit)would be fine and probably last the life of the machine. hope this helps, G
[img][/img] 1977 KZ1000A1
  • bountyhunter
  • bountyhunter's Avatar
29 Oct 2008 22:54
#244586
+1
If you put grease on it, that tends to gunk up over time.
I cleaned mine with carb cleaner spray and used light oil on it.
  • thadley55
01 Nov 2008 19:38
#245071
Sorry I thought my bike was posted somewhere. This is about my KZ900 76' model. I used clear dielectric grease and it has stopped it from advancing so I had to take it back apart and clean it again. It seems to be working better. It is still sluggish at low RPM's but I'm not sure that is an advancing issue.
ThanksB)
  • MFolks
  • MFolks's Avatar
01 Nov 2008 20:40
#245075
Some light oil like 3 in one or sewing machine oil works well as a lubricant.
  • timebomb33
01 Nov 2008 21:30
#245087
just use moly it won't fling off it will repel moisture and it wont dry out and it actually adheres to the parts.
