need help with electical prob.
- bparker
19 Oct 2008 01:21
I have a 1984 zn1100 b1 ltd i have developed a short somewhere. when i turn the key on the fuse for the horn pops. i have changed the ignition switch because it was worn out. i have changed the turn single and horn switch assembly. i checked the rectifier and found the wire that goes directly to the igniter had burnt the conector on the rectifier end. i spliced a new end and replacced the rectifier.
turned on key and fuse blew again. i love this old bike just had a custom paint job and really want to get some miles in before winter. bike still runs though. any suggestions
B. Parker
1984 ZN1100 LTD B1,
Woodward Ok.
1984 ZN1100 LTD B1,
Woodward Ok.
- bountyhunter
Re: need help with electical prob.
19 Oct 2008 16:33
These kind of things are terrible to diagnose. Get a schematic and start pruning one line at a time off the power feed that is popping the fuse: unplug stuff and see what line is popping the fuse. When you find that line, try to zero in on the part that is flaky.
- timebomb33
20 Oct 2008 22:25
is it possible the new body work and your electrical problem are related, maybe pinched of a wire or one has rubbed thru when you put the body work back on. option 2 pull the horn of and hook- up 12 volts to directly and see if it blows if it does you have eliminated part of the problem and since you have the horn out of the system put another fuse in and see if it blows.that might solve your problem.
I THINK MY POWERBAND BROKE
