electric cooling fan
- PLUMMEN
18 Oct 2008 23:24 - 18 Oct 2008 23:37
im on a roll here tonight guys!:laugh: ive been tossing the idea of mounting a small 12v fan between backbone tubes in the area where coils normally sit to pull air over the top side of motor while idling,does anybody know of some kind of a small motor that would fit and still be able to handle the heat generated?everybody gave me hell about progress so here i go again!:laugh:
Last edit: 18 Oct 2008 23:37 by PLUMMEN.
- Makarth
Re: electric cooling fan
18 Oct 2008 23:45 - 18 Oct 2008 23:50
they used to make computer fans up to 90mm that would move 120cfm and spun at roughly the speed of light. i thought about putting one on my oil cooler.:woohoo:
edit: called "tornadoes" and they are 12v
edit #2: around 80 decibels too
edit #3: www.google.com/product_url?q=http://cabl...gl=us&hl=en&sa=title
edit#4: mmmmmmmm edits yum
Last edit: 18 Oct 2008 23:50 by Makarth.
- PLUMMEN
18 Oct 2008 23:53
that looks perfect,ill check measurements tomorrow!Thanks
- Makarth
18 Oct 2008 23:58
no prob, oh and be mindful of the blades i lost a nail on one :S it's what happens when you try changing comp parts with those blades running.
- bountyhunter
19 Oct 2008 16:35 - 19 Oct 2008 16:37
Makarth wrote:
BTW: those fans usually run on DC motors which have a solid state controller inside that regulates speed and limits current in case the fan is blocked (stalled). I don't think those controllers will like getting too hot?
Buy the small chrome fan guards that go in front of them. Worth the extra few bucks.:laugh:no prob, oh and be mindful of the blades i lost a nail on one :S it's what happens when you try changing comp parts with those blades running.
Last edit: 19 Oct 2008 16:37 by bountyhunter.
- Makarth
19 Oct 2008 17:14
no telling. i have a habit of making things just to see them ignite in a giant fireball or not. I think he'll be fine and if not he ruined a 11 dollar fan. Some of these fans can take a bit of heat.
- PLUMMEN
19 Oct 2008 21:15
i want to mount it behind steering head gusset right above/front of cylinder head.
- bountyhunter
19 Oct 2008 21:37
PLUMMEN wrote:
By coincidence, I used to design cooling systems for electronic equipment.
I can't help but wonder if that small fan would actually do anything? In electronic systems, those fans are designed to deal with power dissipation of maybe ten or twenty Watts. A bike engine is probably dissipating thousands of Watts or more.
- PLUMMEN
19 Oct 2008 21:39
im trying to find something capable of pullng cooler air across topside of motor,any suggestions?
- Makarth
19 Oct 2008 21:48
hmmm you don't have a whole lot of spare power to be throwing into a cooling system other then using a fan off a water cooled bike. Would getting a small fan and using it on an external oil cooler be a better idea?
- PLUMMEN
19 Oct 2008 21:57 - 19 Oct 2008 22:14
im open to all suggestions,i moved the chassis and motor to my new office right in front of my desk to make it much easier to visualize any ideas!:laugh:
Last edit: 19 Oct 2008 22:14 by PLUMMEN.
- Makarth
19 Oct 2008 22:34
maybe a temp controlled methanol injeciton? cools the engine internally and prevents preignition.
