Lighted tag bolts / turn signals
  • seanof30306
  • seanof30306's Avatar Topic Author
13 Oct 2008 20:37
#241693
So, awhile back, I came across this website that sold a variety of lighted tag bolts that could be used to illuminate the tag, act as additional brake lights, or serve as turn signals, which is my intended use. They even had some that bolted into the top and bottom tag holes and were shaped like arrows.
I can't find them anymore. Has anyone seen these?
Thans
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • MFolks
  • MFolks's Avatar
Re: Lighted tag bolts / turn signals
13 Oct 2008 20:55
#241698
www.jpcycles.com and www.denniskirk.com might have what you need.
  • seanof30306
13 Oct 2008 22:31 - 13 Oct 2008 22:32
#241702
OK, I found 'em again.
Here's the first one i was looking at:
store.58cycle.com/product_p/122-bracket%20led.htm
I'd also seen these in the Lockhart Phillips catalog (page 167 ... it has an actual photo where you can see the LEDs. Scroll down to the Bat Ray
s7d2.scene7.com/s7ondemand/brochure/flas...artPhillipseCatalogL
These guys are a little cheaper on it:
store.58cycle.com/product_p/122-bat%20ray.htm
These are the screw lights:
store.58cycle.com/product_p/122-dot.htm
I kinda like this one, but don't know how visible they would be:
store.58cycle.com/PhotoGallery.asp?ProductCode=122%2Dstealth
I Like this one a lot, too.
store.58cycle.com/ProductDetails.asp?Pro...ode=122%2DBike+Night
opinions?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 13 Oct 2008 22:32 by seanof30306.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
14 Oct 2008 23:56
#241887
I went with the lighted tag bolts, found 'em on eBay, which is also where I found my tail lights and the integrator that ties them together.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
