'79 KZ650: connectors for voltage regulator
  • seanof30306
  • seanof30306's Avatar Topic Author
09 Oct 2008 00:20
#240878
1979 KZ650 B3
Previously, we swapped to a later voltage regulator with the additional brown wire that ran to a switched 12v power source, which necessatated doing away with the connector and connecting each wire individually.
Now, with a new voltage regulator that does not have the brown wire, the new guy I have working on the bike prefers to return to a factory-type connector. Does anyone know where I can get those connectors?
Also, my regulator has 2 yellow wires, 1 black wire, and 1 white wire with a red stripe. Since the factory connector has been done away with, it is possible that those two wires may have become reversed. Does it matter if the yellow wires are switched up going into the regulator? If so, how do you determine which is which?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • wiredgeorge
  • wiredgeorge's Avatar
Re: '79 KZ650: connectors for voltage regulator
09 Oct 2008 06:09
#240902
The yellow wires are AC and it doesn't matter which goes to which wire on the regulator. The black is ground and white/red is DC out. You can buy connectors at www.z1enterprises.com or www.vintageconnections.com
