1982 kz 1000 speedo question
- clc
07 Oct 2008 04:50
I have an 82 kz 1000 j model. It has a non working electric speedo on it. I want to change it out to a cable driven speedo. Can I use the cable drive from the front wheel of any kz 1000? Or is there a kit for changing the over to cable driven?
Thanks for any help.
- trippivot
Re: 1982 kz 1000 speedo question
07 Oct 2008 09:29
I have had luck with the ratios being same with various japanese gauges and wheel speedo drives.
does the wheel have a place for it, under a spacer ?
close inspection and research on buykawasaki.com
- coppertales
07 Oct 2008 11:57
Check your wiring between the wheel sensor and the plug in the headlight shell. I have had two bikes with inop speedos fixed by fixing broken wires in this harness. There are speedo sensors on ebay right now....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- clc
07 Oct 2008 16:08
I am wanting to do away with the electric speedo. I have just completed chopping the bike and would like a very small speed on it.
Thanks
Thanks
