Front brake switch...adjust?
- sbulla
- 1980 KZ1000 LTD
03 Oct 2008 16:59
I think I know the answer to this but, I'll give it a try here first...is there anyway to adjust the pressure switch for the brake light in the front brake line of my '80 KZ1000B4?
It will make and illuminate the light under hard braking but, with the pressure I use for ordinary stops, it doesn't operate. I hardly ever use the rear brake except for a panic stop so, I'm concerned about the failure to signal folks behind me when in traffic.
Think a new switch would cure it?
Sonny
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- drmadd95
Re: Front brake switch...adjust?
03 Oct 2008 17:52
Well I hope I'm wrong.... but I don't think there is any adjustments for it. Maybe we can find a switch that runs on lower pressure?
I too have this problem on my kz650, but I always press down on the rear brake to make sure the brake light comes on.
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
- fixer5000
04 Oct 2008 04:17
this is a very common problem and they arent adjustable. my 650 is pretty much the same way. unless im mashing it good its not touchy enough. like doc says above i just touch lightly on the rear to let em know hey im stopping !!
1978 kz650b pretty much stock
massachusetts
massachusetts
- The Milkman
04 Oct 2008 04:26
When I first got my 650 the front switch was like that, I did a total flush of the system, took the switch off and flushed some fresh fluid through that port too and cleaned the switch itself with Brakekleen. There was a bunch of garbage that flushed out of the switch. Everything is fine now, barely have to pull the lever and the light is on.
- rstnick
04 Oct 2008 10:08
My front switch hasn't worked in years.
I have the rear switch adjusted to come on with the slightest touch of my foot.
I like Milkmans fix above.
I will have to try that.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- sbulla
- 1980 KZ1000 LTD
04 Oct 2008 12:23
The Milkman wrote:
I did the flush thing awhile back but I didn't remove the switch. Guess I'll have to try that the next time I feel like getting brake fluid all over EVERYTHING.
Thanks,
Sonny
Thanks,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- coppertales
07 Oct 2008 12:06
You should really start using both brakes when stopping. It is easier to correct a skidding rear tire than a skidding front tire....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- sbulla
- 1980 KZ1000 LTD
07 Oct 2008 12:28
coppertales wrote:
I'm pretty sure my years of road and dirt riding experience has taught me which brake or what combination of brakes to use on whatever type of surface I happen to be on. I'm new to this forum, not new to riding.
What I am talking about in this post is, stoplight to stoplight traffic on clean dry pavement and 35mph limit.
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Bluemeanie
07 Oct 2008 13:05
I was having problems with my front brake switch. Found that pin coming out of switch contacts lever at an angle and had worn down pin at an angle. Rotated pin and applied a little lube and has been fine for a few years except for now so may have to replace it. I may pull it out and come up with something, I'm good at fabricating things.
- SPARKY47
- 1980 KZ500 B2
07 Oct 2008 15:02
why not put a sleeve on it?
1980 KZ500 B2
