Speedo Needle
- 1982ltd
Speedo Needle
27 Sep 2008 16:06
Do anyone have a quick fix for spedometer needle jumping eractically after 100 KM/60MPH. Example, when driving at 110, the needle is jumping between 100 and 115 KM per hour. Thank You!
- MFolks
Re: Speedo Needle
27 Sep 2008 18:08
Has the speedo cable been pulled,cleaned,re-lubed(with a light grease)and re-installed?
After cleaning look for broken strands of wire on the inner cable as these might be giving the speedo a spurious signal.
- 1982ltd
Re: Speedo Needle
29 Sep 2008 13:35 - 29 Sep 2008 13:39
As far as I know, It has not been cleaned. But I forgot to mention that it is an electronic speedo on a 1982 KZ 1000 Ltd.
Last edit: 29 Sep 2008 13:39 by 1982ltd.
- Tony
Re: Speedo Needle
29 Sep 2008 13:59
Hi 1982ltd,
I moved this thread to the appropriate forum. If you look in the electrical section you will find your thread.
ELECTRICAL
Battery, charging system, ignition system, electrical starter system, ignition switch, lights, turn signal circuit, horn, gages, speedometer, tachometer, etc.
Good luck with your speedometer.
ELECTRICAL
- MFolks
Re: Speedo Needle
29 Sep 2008 15:06
Broken or almost broken wire, loose solder connection,possible circuit board problem. All point to opening up the speedo/tach instruments and take look inside.
