horns
- quader98
horns
26 Sep 2008 02:52
hello folks,i need new horns, do i have to get new old stock or can i just use what fits? does anyone have any suggestions or links that i can look at... thank you
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
82 GPZ 750 R1
- Old Man Rock
Re: horns
26 Sep 2008 05:36
For the most part, any 12Vdc horn that fits will work... Find one with the highest decibel (db) rating you can find. The higher the number the louder the horn...
Any local motorcycle store usually has them in stock in the price range from $15 and up pending what your looking for.
Just to name a few...
www.jpcycles.com
street.parts-unlimited.com
www.z1enterprises.com
www.oldbikebarn.com
www.jcwhitney.com
www.motorcycle-superstore.com
OMR
www.jpcycles.com
www.oldbikebarn.com
www.jcwhitney.com
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- tjhiggin
Re: horns
26 Sep 2008 07:41 - 26 Sep 2008 07:42
Stock horns come up regularly on ebay.
Horns that "beep" are not as loud as horns that "honk," i.e. air horns. You can get modern air horns that have the compressor built-in, mount easily, and require no rewiring.
Here is a thread from last year describing my horn upgrade. The last post in the thread has some interesting links.
Good luck and keep us posted on any new products you discover.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
Last edit: 26 Sep 2008 07:42 by tjhiggin.
- MFolks
Re: horns
26 Sep 2008 11:03
Another horn source is at
www.griotsgarage.com
1.#77585 $69.99 Black, Big Truck Sound Air Horn
2.#77839 $39.99 Red, Compact Italian Air Horn
3.#77505 $39.99 Black,Ultra Compact Air Horn
4.#77573 $69.99 Red, Hella Horns
Horn wiring diagrams can be found at www.rallylights.com
- Vter Bob
Re: horns
27 Sep 2008 11:07 - 27 Sep 2008 11:09
My horn of choice is the Stebel Nautilus. It's 139db. You can find them on ebay in the $40 - $50 range but sometimes I've seen them much cheaper. They come with a 12 volt relay and are wired in ala WiredGeorge's coil mod in that the original trigger wire switches the relay which delivers full battery power to the horn.
tinyurl.com/4fuw8g
Hint: should you do this horn installation, tip your mechanic to check the horn outside before rolling the bike in for an inspection.
Don't ask how I know this..... :laugh:
tinyurl.com/4fuw8g
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
Last edit: 27 Sep 2008 11:09 by Vter Bob.
- quader98
Re: horns
28 Sep 2008 06:17
thank you,ive been looking at all the suggestions and like the air horns but where can you mount them and how do they look mounted?
82 GPZ 750 R1
82 GPZ 750 R1
- Vter Bob
Re: horns
28 Sep 2008 08:01
The Nautilus requires one bolt to mount and I have mine mounted in the original horn location on the 1000. The 1000 originally had twin horns and IMHO the Nautilus is no more or no less ugly than the original horns. On the 550, I have a Vetter fairing and the horn is kind of tucked up behind it and does not show at all. The Nautilus needs no compressor and the only restrictions are the angle at which it can be mounted is limited and the air intake has to face backwards and not into the wind. (They supply a tube to route the intake if needed.)
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1981 KZ550 LTD
1982 KZ1000 LTD
- quader98
Re: horns
28 Sep 2008 10:11
have any pics of what it looks like on your ride?
82 GPZ 750 R1
82 GPZ 750 R1
- Vter Bob
Re: horns
28 Sep 2008 11:26
Spend all my money on bike parts and gas, no digital camera. I'll see if I can get my friend to take some and post ASAP.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1981 KZ550 LTD
1982 KZ1000 LTD
