Ignition Switch
- drmadd95
Ignition Switch
25 Sep 2008 10:58 - 25 Sep 2008 10:59
On my 79 KZ650B I was going to swap out my ignition switch for one from a 78 KZ650D. I thought they would be identical; however, the 79 has one extra wire coming from the switch (separate from the 6pin harness) that the 78 doesn't have. Any ideas on what this is for? I didn't want to swap them out not knowing what this extra wire is for.
Thanks
Thanks
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
Last edit: 25 Sep 2008 10:59 by drmadd95.
Re: Ignition Switch
25 Sep 2008 13:33
If not already done, might help to look under KZ information "Filebase" and compare ignition switch connections in the wiring diagrams for '78 and '79 to determine which additional wire was added in '79.
Good Luck!
Good Luck!
- Royal1MC
- Is it just me, or is it just great to be on a KZ
Re: Ignition Switch
25 Sep 2008 15:19
Is it a brown wire? If it is, then it's +12v switch wire. It should only be hot when the ignition switch is turned on.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Los Angeles, CA
- drmadd95
Re: Ignition Switch
26 Sep 2008 08:20
Thanks, I'll check out that database. Also I'll test that wire when I get home from work, I think it was a brown wire.
- drmadd95
Re: Ignition Switch
02 Oct 2008 00:45
Yeah, the ignition switches between the 78 and the 79 are not compatible according to the diagrams. I wanted to swap them since the 78 has two original keys and was in better shape.
I ended up taking both switches apart and swapping the tumblers. I then swapped the seat and the steering locks as well. Now everything matches and I have two original keys.
