Is it stock?
- sbulla
- 1980 KZ1000 LTD
Is it stock?
24 Sep 2008 08:31
In checking over my recently acquired '80 KZ1000 B4, I finally removed the case guards so I could get at the points cover and, I found this (see pic). The only markings on it are "Japan". I checked some parts breakouts online and found that it is probably stock. My manual (PDF scan) only shows points type ignition but I have the Kaw IC ignitor box mounted under the right side cover also. The PO installed gray Dyna coils (2.2 ohm) with yellow copper plug wires.
Should I be thinking of upgrading to a full Dyna system or, as this is still working, stick with what I have? Also, what plug gap should I run? Right now I'm at .034 and they seem to be OK.
Sonny
Sonny
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- Jack
Re: Is it stock?
24 Sep 2008 08:42
That's the stock Kawasaki pickup for '79 & '80 KZ's including the LTD. Don't know why the PO put 2.2 ohm Dyna coils on it, suprised they work- most Kaws including my '79 MKll which had the same ignition are 3.0 ohm Green coils.I use a Dyna S pickup with green coils and run about .028 -.030 gap. The advantage to the Dyna S is you can move ignition timing around easily for tuning ; you have to slot the plate of the oem unit to be able to move timing from factory setting.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- loudhvx
Re: Is it stock?
24 Sep 2008 09:00
Most of the ignitions of that style came with coils in the 2.4 to 2.6 ohm range. Some of the early (79 & 80) versions came with different coils and possibly a ballast. The 2.2 should work ok even if they draw a tiny bit more current. If the module burns out, you can make one for about $30 or $40.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- sbulla
- 1980 KZ1000 LTD
Re: Is it stock?
24 Sep 2008 12:03
loudhvx wrote:
Gee, why would I do that when Babbits has them for only $525.50! :ohmy:
Sonny
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- wiredgeorge
Re: Is it stock?
25 Sep 2008 07:31
Sonny, that is the stock IC ignitor pickup coil set. If it is working, put the cover back on and leave it alone till you have to push the bike. If you do use Dyna 3 ohm coils, I would remove the ballast resistor, if one is installed. The thing probably has more resistance now than when installed anyway and will just lessen your spark. If you have the stock coils, just leave the ballast resistor in place although I would test resistance to see if it is still in spec.
- loudhvx
Re: Is it stock?
25 Sep 2008 11:04
sbulla wrote:
I know. What a bargain! :laugh:
loudhvx wrote:If the module burns out, you can make one for about $30 or $40.
Sonny
1981 KZ550 D1 gpz.
Other links.
Other links.
