No Start
  • Mikesz28lt1
  • Mikesz28lt1's Avatar Topic Author
No Start
22 Sep 2008 15:29
#238229
82 KZ1000 LTD, won't start when hot, solenoid just clicks. Blew turn signal fuse, replaced fuse, now left turn signal only works sometimes, right works fine. Are the turn signals somehow wired into the starter? Both problems started at the same time. I checked the turn signal wiring and did not find anything.
  • BSKZ650
  • BSKZ650's Avatar
Re: No Start
23 Sep 2008 05:43
#238303
the turn signal problem is prob is going to be the flasher, as far as not starting when hot, have you checked the battery?
77 ltd1000, current rider
76 kz900, just waiting
  • keith1
  • keith1's Avatar
Re: No Start
25 Sep 2008 17:09
#238670
electrical is not my strong suit but definitely check battery status....a bad battery will do a host of funky things.....
  • MFolks
  • MFolks's Avatar
Re: No Start
25 Sep 2008 20:58
#238697
All battery and starter solenoid connections must be clean and tight including the engine ground connection.
Is the battery in good shape? have you done a specific gravity check after charging it?
