Difference between Motorcycle and Auto Plug Wire
  • 83GPZ
  • 83GPZ's Avatar Topic Author
22 Sep 2008 13:38
#238216
I have some very expensive taylor 8mm performance wires that I bought for my car. I was wondering besides the length what is the difference and could I use them on my 83GPZ 1100 if I shorten and transfer the caps?
Also, I have a new set of 3ohm green dyna coils and wires that I bought for my 82 GS1100. Would they work on GPZ?
Thanks
Tee
  • MFolks
  • MFolks's Avatar
Re: Difference between Motorcycle and Auto Plug Wire
22 Sep 2008 14:44
#238224
What kind of coils are you running? If Dyna they might have a tight fit as I think the Dyna's will accept 7mm.
If you have stock coils and the old wires are part of the coil I think a splice kit is available. If your new wires are copper they might interfere with the FI system or are you running carbs?
  • 83GPZ
22 Sep 2008 15:49
#238230
I am running the stock coils and wires. I will look at the coils to see if the wire is a part of the coil. Will I be able to replace the stock coils/wires with DYNA coils/wires if the wires are not copper?
Thanks for the information,
Tee
  • steell
  • steell's Avatar
22 Sep 2008 16:36
#238237
The Dyna coils and wires will work fine on your GPz1100, we just finished installing Dyna coils and wires on the GPz750 Turbo.
  • 83GPZ
22 Sep 2008 19:06
#238259
Here are the coils and wires that I bought for my 82 GS1100. I would really like to run this setup on my fuel injected 83 GPZ1100.
Any help would be appreciated.
Thanks
Tee
