- Thank you received: 75
Starter Clutch - kz750B
- Rainman
- and a little Kaw shall lead them
If so see next post(haven't got the hang of multi-pix posting yet).
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
- Rainman
If you remove the three allan bolts (or they are loose) use some blue lock-tite on the threads when assembling. When these screws come loose they tear the gear to pieces and may even lock up the engine. Bad if running, really bad if riding. Brass thrust washer must be in place when re-assembling.
Jim
Quincy,IL
- AtLarge
- Thank you received: 21
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
- blumeri
- Thank you received: 1
- Rainman
blumeri, the cover looks to be crimped on to the machined ring (enlarge picture of disassembled clutch).
A rotated cover with the bolt slots over the rollers could be the problem. The rollers could be cocking slightly (only takes one to keep the assembly from locking on to the starteg gear hub). Try to rotate the cover untill the three holes in the outside of the cover align with the thru holes in the machined ring. When the outer holes are aligned like this
the slots will line up with the bolt heads and the rollers will be covered,like the picture of the assembly. If the clutch and flywheel is still on the end of the crank, you may be able to use the end of a screwdriver and "tap" the cover untill the holes line up. When one is in line they all will be in line.
Good luck.
Jim
Quincy,IL
- Rainman
if it comes loose the starter will just spin and you might find yourself in the parking lot of your local DMV, on a busy afternoon(lots of lookie-loos for the next part), removing the side cover to tighten the LH thread bolt and also finding out that a 750 twin will pour oil out the side cover seam when on the side stand but not when on the center stand.
Good Luck.
Jim
Quincy,IL
- bountyhunter
- Thank you received: 337
Good visuals. Thanx for posting those up Jim.
Here is the secrets courtesy guys smarter than me:
1) The big 17mm bolt holding the flywheel on is REVERSE thread. To remove it, use a huge flat blade screwdriver with the tip hooked in one of the holes in the flywheel and the end of the screwdriver against the posts that hold the footpegs. It works, I did it.
2) use a big wrench and TAP the end of the handle with a hammer (clockwise to loosen)
3) PULLING THE FLYWHEEL:
Use the rear axle on the B models as a wheel puller. It threads into the flywheel hub and pushes against the end of the crankshaft. use two screwdrivers in the hole through the axle head for twist force. I swear it works, I just did it.
- bountyhunter
I would be afraid to. My manual says that bolt is torqued to about 120 ft-lbs.nut, bolt, fasterner, :silly:
ahhh, so that's the one that's left hand threaded...that being the case, when turning it, should i have it in gear? would that stop the whole assembly from rotating?
- blumeri
Can't turn the cover at all. I don't have a big enough vise to really hold it still, but I bought the worlds largest pipe wrench and modified it so it would open enough to grap the cover. I tried holding the flywheel with a strap wrench and I couldn't move it at all. I thought prying it out a little might loosen the cover, but all I did was bend it.
I'm about ready to drill through it so I can at least access the screws to remove the starter clutch from the flywheel. I would then need to find a source of a a new cover. Any ideas? I saw that Bountyhunter (on this site) said he got a starter clitch assembly from a Clint Pulliam and gave an email address in a related thread. Know anything about either of them?
- bountyhunter
www.motolane.com
I have had good luck with a few purchases from him on used parts. Good quality, fair price. Obviously, YMMV whenever you are buying used parts off old bikes.
NOTE: I still have a complete 750B starter clutch assembly I bought as a spare with every single part including the housing/cover, rollers, springs. pins, and the large gear with the starter chain. I paid $70 for it and I'll let you have it for $60 and throw in the shipping if you want it. I haven't tested it, but the condition looks good as far as I can tell (no rust). I got it from Clint, BTW.
- blumeri
- bountyhunter
OK, Ill send a PM.Sounds good do you want to PM me with how you want to carry out the transaction?
