trigger wire question wg mod
  • bigkzfan
  • bigkzfan's Avatar Topic Author
  • if grandpa had tits he"d be grandma, if
18 Sep 2008 15:32
#237655
hey guys i have an 82 1000 j model and i see where the yellow red comes down from kill switch to a connector question is do i cut yellow red wire before or after the connector?? everything else is pretty straight foward....thank you in advance, john...obviously doing the coil power rewire
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
  • wiredgeorge
  • wiredgeorge's Avatar
Re: trigger wire question wg mod
19 Sep 2008 07:08
#237759
Don't cut the connector. Unplug it. Crimp a connector on the wire you will run for the trigger. Plug the OUTPUT of your new relay pin #87 into the one into two connector that leads to the coils and you won't even have to unhook the wires from the coils.
  • bigkzfan
19 Sep 2008 12:05
#237801
ty george got her finished up early this after noon just gotta throw a new set of plugs in and go..i have 12v perfectly to both power feeds to the coils..took me a couple hours but i wanted to get it done right the first time.i spent a few days getting my plan of attack down and got her done
  • bigkzfan
19 Sep 2008 16:18
#237831
actually after i finished her up i charged the battery up to full and i had 12.45v at both coils......up from 11.65
