starter clutch and the "inside" of the stator
- School Teacher
13 Sep 2008 22:34
ok the inside partof thestator that has the magnets in itan spins, well it spun on the end of crank and i need a new one. the problem is it is on my 77 i have a 76 and a 79 as parts bikes will either work?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- MFolks
Re: starter clutch and the "inside" of the stator
14 Sep 2008 12:27
Your "rotor" has spun on the shaft as a result of the bolt holding it on got loose or was never installed correctly.
Some engines had left hand thread bolts so be careful removing another rotor from a parts bike.
I do not see any reason not to switch parts. I'd get some Loctite 242(light blue color)from the auto parts store for the new rotor and you should not need to get into this area again.
- School Teacher
14 Sep 2008 14:46
MFolks wrote:
i guess i should say on the 76, the rotor (anyone know the real name?)has a keyway and the 77 doesn't and the 79 is a total different animal all together.
so is the taper the same? can i use the one with the keyway on a non keyed crank? help:S
1980 kz1000G1
1980 kz1000G1
- School Teacher
14 Sep 2008 16:04
School Teacher wrote:
my typing was worse than normal on the above post,tiredof working on it is my only excuse
1980 kz1000G1
1980 kz1000G1
- wiredgeorge
14 Sep 2008 16:51
I wouldn't think the 79 would work as it is an entirely different animal. Not sure about swapping the keyway vs non-keyway as they are essentially the same only one has the keyway. I would guess you could. The thread on those will be normal lefty-loosey / righty tighty.
- coppertales
15 Sep 2008 10:26
Go over to the Kawasaki site and pull up the parts diagram and cross reference the part numbers to see if they are the same. Look at the pictures too to see if they look the same....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- School Teacher
15 Sep 2008 10:45
ive actually seen the parts in question now the 76 looks like it is the same -the key way and a groove for a washer.
anyone have a 77-78 stator rotor thingy they would be willing to sell?
1980 kz1000G1
1980 kz1000G1
- steell
15 Sep 2008 18:14 - 15 Sep 2008 18:14
According to Kawasaki.com, the following models all use the same rotor.
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
KZ900-A4 (1976)
KZ900-A5 (1977)
Last edit: 15 Sep 2008 18:14 by steell.
- School Teacher
15 Sep 2008 21:23
thanks i will tear into one of the 76's and see what i have. i must have gotten into a 75 motor and didn't know it thanks
1980 kz1000G1
1980 kz1000G1
- wiredgeorge
16 Sep 2008 06:00
You can check the motor number on zedder.com - I think even a Z1 rotor thingy (I think that is the technical term used) would work. Keep in mind that if you are having starter clutch issues, that the gear under the stator is shimmed. This is because they require a certain clearance from the engine cases to work right. You should measure this clearance if you are having starter clutch problems or if you change the rotor thingy. Roy-B-Boy-B put me onto this... there are three thickness of shims in the Kaw parts catalog and if you have a bunch of engines, there will be different shims used to gain this clearance.
- keith1
21 Sep 2008 14:51
wiredgeorge wrote:
i just did my starter clutch and i bought all 3 sizes of damper just so i would have what i needed just in case .they come in 6.3, 7.3 and 8.3 look for the little stars embossed in the rubber part ..
1 star is a 6.3, 2star is a7.3, 3 stars is 8.3...
expensive little buggers.....
- School Teacher
22 Sep 2008 22:05
keith1 wrote:
i don't know what your talking about please explain.
thanks
ps i changed out the rotor and every thing seemed fine till the next day tried to start it and the starter just spun- so i pulled the cover and BLAM! im back to the drawing board ! don't wann mess up stator 3,
jb weld? superglue? airplane epoxy? weld the dang thing on ! buy a new one from kawsaki $770 help! frustrated and wanna ride on the few days worth riding that are left...
wiredgeorge wrote:You can check the motor number on zedder.com - I think even a Z1 rotor thingy (I think that is the technical term used) would work. Keep in mind that if you are having starter clutch issues, that the gear under the stator is shimmed. This is because they require a certain clearance from the engine cases to work right. You should measure this clearance if you are having starter clutch problems or if you change the rotor thingy. Roy-B-Boy-B put me onto this... there are three thickness of shims in the Kaw parts catalog and if you have a bunch of engines, there will be different shims used to gain this clearance.
thanks
1980 kz1000G1
1980 kz1000G1
