when hot no spark or weak on #2-#3 wires
- My1stKZ750
08 Sep 2008 14:00 #236176
by My1stKZ750
when hot no spark or weak on #2-#3 wires was created by My1stKZ750
1980 KZ750H LTD 4 cyl. When i ride for a long time on a hot day and than shut bike off for several minutes than when i restart bike it runs extremely rough no power. So i pulled plug wires one by one. found 2 3 no spark.
i pulled the 4 wire connector from the IC ignitor. like the book says to test ohms across black and blue i have 500ohms yellow and red i have nothing. but if i let bike sit for an hour or put a fan onit it starts up and runs fine.
any Help??
any Help??
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
08 Sep 2008 14:37 #236177
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic when hot no spark or weak on #2-#3 wires
Where physically is the ignitor mounted?
If it's being heated by the engine you could have an intermittant thermal fault.That said,how good are the connections?
1980 KZ500 B2
- wiredgeorge
09 Sep 2008 05:39 #236293
by wiredgeorge
Replied by wiredgeorge on topic when hot no spark or weak on #2-#3 wires
Replace the IC Igniter pickup coils and electronic module with a Dyna S ignition.
www.z1enterprises.com
- sure sounds like the igniter is bad and in need of replacement.
- badr0bot
25 Sep 2009 18:20 #323933
by badr0bot
87 KZ1000 P1
Replied by badr0bot on topic when hot no spark or weak on #2-#3 wires
I've had this exact same problem off and on as well and it seems to have started again tonite. I put a lot of trust in Wired George so I tested his theory first. Testing my coil secondary resistance, I first thought I had a bad coil since I could not get a circuit between the two pins. fiddling a little more and putting my leads down to the bottom of the pin connector at the base of the connection to the coil body would give me a reading of 12.4K ohms off and on. I figured that there must be a lot of corrosion on the coil pins which are very hard to clean since they are inside the threaded housing of the coil. I put some vinegar around the pins and let it soak while I folded some 400 grit sandpaper to further clean those pesky pins.
That seemed to do the trick. It runs good now. I think it was a bad connection between the plug wires and the coil. That push-on connection has always seemed to be a bit problematic.
87 KZ1000 P1
