Fried my selenium rectifier/wiring and replaced w/ silicon
  • krazykat
  • krazykat's Avatar Topic Author
07 Sep 2008 19:19 - 07 Sep 2008 19:23
#236042
I got a new batter for my 77 KZ-750 twin and the battery terminals were reversed from the previous battery. Needless to say, I made an amateur mistake and hooked it up backwards.
I fried some wires and rectifier before I could unbolt the terminals. Luckily it was very localized damage. I stripped the harness a bit and checked it all out.
So, I replaced the wires and put a newer style rectifier from another kawasaki on there which had the same wire colors and plug. I'm getting 14.5 volts running and the bike runs great.
I just wanted to make sure this is ok and there are no side effects to doing this. Thanks for the input.
77 KZ-750 ~10k original miles and a few tweaks
Last edit: 07 Sep 2008 19:23 by krazykat.
  • MFolks
  • MFolks's Avatar
Re: Fried my selenium rectifier/wiring and replaced w/ silicon
07 Sep 2008 19:23
#236043
I'd check the wiring real good because you don't want to be stranded when a wire(s) was missed that's now marginal(burned insulation,melted connectors, etc).
  • krazykat
07 Sep 2008 19:27
#236044
I agree. I replaced everything that was suspect. I stripped the wire harness a ways back, so I know it's all good. I got pretty lucky that it didn't short long enough to melt adjacent wires.
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
09 Sep 2008 19:11
#236433
The difference between Selenium and Silicon rectifiers is the voltage drop across them, Selenium about 0.2v,Silicon 0.7v:)
1980 KZ500 B2
