Dyna coils
  • boogiepicker
  • boogiepicker's Avatar Topic Author
Dyna coils
06 Sep 2008 16:27
#235856
Does anybody here have a good running kz900 streetbike with dyna 3 ohm coils with no problems?I cant get mine to run right with the 3 ohm coils, tried everyhing u name it I've tried it
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Dyna coils
06 Sep 2008 16:29
#235858
I have two good running KZ900s with Dyna coils, a good running KZ1000E1 with Dyna coils and if I ever get off my tail and start/finish another 1980 KZ1000E2 project, I will have yet another good running KZ with Dyna S coils.
I bet if I owned your bike for about 10 minutes, I would have a 5th good running KZ hehe
  • MFolks
  • MFolks's Avatar
Re: Dyna coils
06 Sep 2008 16:31
#235859
What kind of ignition are you running? the stock points or the factory electronic ignition with the IC Ignitor?
  • boogiepicker
Re: Dyna coils
06 Sep 2008 17:26
#235864
I'm running a dyna module and coils 3 ohm
  • boogiepicker
Re: Dyna coils
06 Sep 2008 17:27
#235865
Thanks that helps me out alot. are you running 3 ohm coils?
  • MDawnz1
  • MDawnz1's Avatar
Re: Dyna coils
06 Sep 2008 18:26
#235869
What color are they ?
1974 Z1a, still 903
  • boogiepicker
Re: Dyna coils
06 Sep 2008 18:46
#235871
They are green says 3 ohms right on them bought from Z1 I'd like to know if anyone is running the 3 ohm coils on their bikes.
  • MFolks
  • MFolks's Avatar
Re: Dyna coils
06 Sep 2008 19:34
#235875
A slim possibility is a bad coil, can you switch coils around and see if the problem follows the switch?
Get a spray bottle of water and spray the exhaust sytem to find the cylinder(s) not firing, switch coils and see if it's the same.
  • Royal1MC
  • Royal1MC's Avatar
  • Is it just me, or is it just great to be on a KZ
Re: Dyna coils
06 Sep 2008 19:40
#235876
I currently use Dyna 3.0 Ohm coils(green) with a Dyna S ignition. Never had a problem. I agree with MFolks try switching the coils.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Dyna coils
06 Sep 2008 19:54
#235879
Check and make sure the wires (not plug wires) going to the coils are connected correctly. Check voltage going to the coils also.
  • MFolks
  • MFolks's Avatar
Re: Dyna coils
06 Sep 2008 20:15
#235881
The Dyna 3 ohm coils come with terminal lugs that attach to the coils with screws.
How did you crimp the primary wires(red,Green and black) and what screws and lock washers did you use? Could the screws be too long and "bottoming out" before they get tight?
  • boogiepicker
Re: Dyna coils
07 Sep 2008 04:47
#235914
the wires are connected properly,nothing is crimped on I soldered everything,have solid core plug wire soldered ends on that to,did the coil relay mod.I bought the dyna ignition used off ebay the coils are new from Z1enterpises.I was suspecting the module so I swapped the one from my CB750 and it still sputters.When I bought the dyna ignition the guy said he couldn't find the rotor and a few days later found it, is it possible I have the wrong rotor?
