Looking for some easy info
  • stallau
  • stallau's Avatar Topic Author
05 Sep 2008 18:47
#235717
I have a 83 KZ550-M1 and I want to move the tail lights back so I can add some saddlebags. What size wire should I use and how easy / hard should that be? I figure I'll just be adding an extension of the wiring from the current place.
Any thoughts on some styles. I love LED's but I've also read a lot of problems with the power draw difference.
Thanks
Re: Looking for some easy info
05 Sep 2008 19:09 - 05 Sep 2008 19:13
#235727
Used same size wire as already on bike to create the extension needed. Good Luck! :)
[Click on image to enlarge view]
Last edit: 05 Sep 2008 19:13 by Patton.
05 Sep 2008 19:12
#235728
Here's another. :)
  • MFolks
  • MFolks's Avatar
05 Sep 2008 19:25
#235731
If you are just moving the light further back 18 gauge wire will work fine. I have some websites for the electrical connectors:
1. www.easternbeaver.com
2. www.z1enterprises.com
3. www.vintageconnections.com
4. www.electricalconnection.com
  • tjhiggin
  • tjhiggin's Avatar
06 Sep 2008 10:14 - 06 Sep 2008 10:15
#235798
If you convert to LEDs just get an electronic flasher from any auto parts store for about $10. It will plug right into your existing flasher socket.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
Last edit: 06 Sep 2008 10:15 by tjhiggin.
